![]() | Home > Technical > Transmission Fluid Weeping -easy fix? |
If it is indeed hydraulic fluid then the clutch slave cylinder seals are the likely candidate, to get to the cylinder on a Puma means a gearbox out job. I would check the fluid level in the clutch master cylinder reservoir and monitor accordingly. Sure it's not oil? Steve.
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
It could be the clutch slave cylinder which is inside the bel housing somewhere and requires the gearbox removing to replace. So definitely get it done under warranty whilst you still have it.
Regards, Mark |
DOH! Beat me too it. ![]() ![]() |
Vizsla Member Since: 18 Nov 2012 Location: Berkshire Posts: 96 ![]() ![]() |
Thanks both
![]() Just did a bit of reading up on this after you posted and it certainly sounds like it is unfortunately the CSC. Its definitely not engine oil (too clear and not viscous enough). What a pain if its gear box removal time and with so little mileage ![]() Its going to the dealers this afternoon now, which is only a few miles away, so they can get it up on their lift & take a good look. I'll feed back what they say. Good job I spotted it while still under warranty I suppose. Paul |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Guy Salmon at Ascot were extremely helpful and have calmed my fears of a transmission fluid leak - it was in fact condensate from the air con ![]() ![]() Apparently the AC vents above the gear box housing and was dripping exactly around the point at which the two bell housing halves meet and looks just like a leak when its just a small amount. ![]() Having run the air con fully on for a half hour journey and reinspected there is a lot more fluid (obviously) now dripping around that point and its clearly water not oil. Few!! Time to now get on with protecting the underside as intended and say sorry to 'Ermintrude' for doubting her reliability ![]() |
