Home > Maintenance & Modifications > upgrade to thatcham cat 1
Page 2 of 2 <12
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Can a battery back up sounder be added to a 90 xs 05plate ? Is it a plug and play item?
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
Post #257066 7th Aug 2013 8:08pm
Porny
Site Sponsor
In 99% of cases the wiring is already in the wing loom.... so yes plug and play. Although I would actually put it in a none standard location.
The only other thing you need to do is change the settings on the 10AS unit with suitable diagnostic equipment.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #257075 7th Aug 2013 8:29pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The backup battery sounder is basically a horn/siren powered by a rechargeable battery that is constantly re-charged. The siren is set off by either a signal from the alarm unit or when the power supply is disconnected. I have fitted a 3 rd party battery powered sounder to a permenant , fused, live supply from the battery. So, if the alarm unit is triggered then the normal alarm sounds. If the battery is disconnected then the backup sounder is triggered.
In fact I have 2 Sounders fitted under the bonnet and elsewhere. They can be disabled with a special key, if you know where the units are. It all helps. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #257076 7th Aug 2013 8:31pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
After Ian's post I'm now doubting myself as I always thought Td5 wing looms were pre-wired but Pumas pre MY12 or MY13 (can't recall when they fitted BBUS as standard) were not pre-wired for BBUS, hence the need for the new loom that KMAC mentioned.
@ DerbyWill, I have an 05 plate Td5 110 XS and found the BBUS connector (brown multiplug, four black wires) lurking behind NS headlamp. Plug and play and all seems to work fine. Echo the view not to place the sounder in usual location as they are a step in the right direction but can be beaten in both a crude and cunning way.
Ian - if you don't mind, would you PM me the changes needed on the 10AS settings (I've got a Nanocom Evo). It all seems to work as it should and I didn't change any of the 10AS settings. I wouldn't mind double checking.
@ Caterham, another option to consider, if you don't mind two plippers, is to run another alarm/immob (Cat1 or otherwise) independently of the existing 10AS alarm/immob. I can't comment if this would work without conflict on a PUMA but it's fine in my Td5 world at least. And yes, fit a tracker or two too Thumbs Up Jon - 110 td5 [sold]. Currently Defenderless.
Post #257106 7th Aug 2013 10:22pm
Caterham
thank you for all the responses.
Post #257166 8th Aug 2013 6:57am
Zim
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I too have read up extensively on the site about upgrading the alarm. My insurer had asked for evidence that my 2007 Defender LR fitted alarm was Cat2. (I can't seem to find this). After having read numerous responses about alarms I have gone for a new alarm system which includes the Blackjax anti hijack, warn away and anti tilt as extras to the base unit.
It is a Clifford G5 650 MK2 alarm which will be fitted in a few days. If you PM me, I will give you the full spec, prices and details of the company fitting it as I also wanted full certification for the insurer and back up. The prices on places like eBay are just for the base spec's with no extra's. 2007 Defender 90 XS
Post #257197 8th Aug 2013 10:30am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Zim
In this Thatcham doc (page 26) you can see all Defenders from 2007 onwards are rated Cat 2 (which means immobiliser only)
The Defender alarm is not certified as even though battery back-up is now standard LR haven't put it forward for certification.
http://www.thatcham.org/files/pdf/compliance.pdf
Post #257279 8th Aug 2013 4:19pm
Zim
Cheers, much appreciated! 2007 Defender 90 XS
Post #257330 8th Aug 2013 8:36pm
derbywill
Thanks Ian and party monkey ill ave a look!
Will 2005 90 XS
Post #257377 8th Aug 2013 10:12pm
mobilecentre
Caterham wrote:
thanks kmac
hmm.
not wanting to poo poo anyone but I don't have the battery back up alarm.
does that suggest the c£500 I've seen quoted to upgrade mine to a thatcham 1 is simply to replace the siren for a battery back up version - seems like alot of dosh?
(but them I'm tight) Laughing
It is the fitment of a complete new alarm in conjunction with the OE immobiliser, most insurance companies should be happy with CAT 2. We can do a cheaper version where you have an additional key fob instead of the all in one key. We could supply for DIY fit but there is no insurance certification with this option.
As has been said the LR battery backed up siren is the cheapest and easiest upgrade.
Cat 2 > 1 upgrade is a days work
Post #258565 14th Aug 2013 9:51am
Caterham
aha,
thanks - that makes far more sense - a complete new alarm. Bow down
does a thatcham 1 car (defender) become almost impossible / practica to steal? clearly this excludes having your keys / fob nicked and having the car lifted.
Post #258592 14th Aug 2013 11:56am
mobilecentre
Caterham wrote:
aha,
It overcomes some weaknesses in the OE system shall we say Whistle
Post #258593 14th Aug 2013 11:57am
Page 2 of 2 <12
