Home > Td5 > Mudstuff dash
Page 2 of 3 <123>
WarPig
It's a shame that carling switches are made upside down. Up for on and down for off !
Post #257932 11th Aug 2013 2:35pm
excossack
It is a shame. Can the rocker part be taken off and turned around? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #257955 11th Aug 2013 3:59pm
WarPig
I think the Mericans are to blame. I'm guessing they are made in the USA?
Post #257956 11th Aug 2013 4:00pm
Retroanaconda
The ones that ARB supply with their lockers (which are based on the Carling ones) operate in what we would say is the "normal" way, ie. press down for on.
Standard Carling switches operate up for on, which is strange. Can always turn them upside down, though then the label is at the bottom.
Post #257964 11th Aug 2013 4:14pm
excossack
The label at the bottom isn't an issue for me. 1999 Defender TD5 110
Regards
John M0VAZ
Post #257965 11th Aug 2013 4:17pm
mobilecentre
Carling make UK spec switches specifically for us which are the "right" way round Thumbs Up
Down for on - bar illuminates when on - square illuminates green for legend
http://www.mobilecentre.co.uk/index.php?ma...ath=60_195
Post #258349 13th Aug 2013 9:03am
excossack
Cheers. Well, when I come to populate the mudstuff dash pod, I might consider them(as being the right way round) 1999 Defender TD5 110
Regards
John M0VAZ
Post #258371 13th Aug 2013 10:37am
WarPig
I didn't know that. I might order a replacement set from you for my console.
Post #258376 13th Aug 2013 11:27am
You could of course turn the switch upside down ....
Post #258390 13th Aug 2013 12:56pm
excossack
....you could but the pre-labelled switches would have the logo upside down. 1999 Defender TD5 110
Regards
John M0VAZ
Post #258391 13th Aug 2013 12:58pm
Pre-labelled ? - I assume you mean the ARB difflock switches ?
Edit: Seen your first picture now.
Post #258394 13th Aug 2013 1:06pm
excossack
Them ones! 1999 Defender TD5 110
Regards
John M0VAZ
Post #258416 13th Aug 2013 3:26pm
mobilecentre
Yes it can
Post #258524 14th Aug 2013 7:22am
mobilecentre
All the rockers / actuators we do are genuine Carling rockers with Legends on from the factory rather than the transfers you rub off a sheet. Here is a sample below
Post #258527 14th Aug 2013 7:30am
mobilecentre
[quote="WarPig"]
You can keep your rockers / actuators and just order the switches - all the suppliers such as MUD, X-ENG etc order the standard range of switches from Carling which is the US spec so exactly the same switch in terms of features function and spec but they can get them off the shelf quickly from a distributor here in the UK but they are up for on.
Here is an article we did a few years back on Carling Switches
http://www.mobilecentre.co.uk/images/Data_...itches.pdf
Post #258528 14th Aug 2013 7:40am
Page 2 of 3 <123>
