![]() | Home > My Defender > Todays USW job... Step bumper |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 ![]() ![]() ![]() |
Fitted the step bumper today... rubbish instructions and some questionable size bolts, but it worked out ok in the end! Had to pop out to the local tractor repair place to borrow a 14mm allen socket though! Painted some of the parts in the kit at the same time... I may well paint the whole thing now as well..
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() ![]() Click image to enlarge |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
Hi Nick
What make as on my list of things to do one day ![]() |
It's the genuine LR one. The welding/finishing is a bit agricultural, some of the bolts aren't quite long enough to fully engage the nylon in the nylock nuts, & they supply 12mm bolts to fit through 10mm holes - but I suppose that's to be expected!!
Standard land rover quality then 2020 P300 HSE
sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568 ![]() ![]() |
Looking good, this is also on my to do list
Reversing sensors are on my to-do list as well...
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
Whatever you do DON'T fit them straight into the crossmember! They will cause it to rust more quickly than you can say 'waxoyl'! They can be fitted (just about) in the rear bumper, it'll have the same effect but at least it's an accessory not the x-member! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
on the rear bumper step, i fitted a small plastic rectangle and mounted the sensors on the bottom edge, the top edge on the bumper step
Interesting, sounds good! If you have any pics they would be much appreciated! Saw a 110 with conpletely rotten rear Xmember due to parking sensors the other day, and it was a '59 plate! Shows what a difference it makes Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
