Home > My Defender > Todays USW job... Step bumper
Nick-St
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Fitted the step bumper today... rubbish instructions and some questionable size bolts, but it worked out ok in the end! Had to pop out to the local tractor repair place to borrow a 14mm allen socket though! Painted some of the parts in the kit at the same time... I may well paint the whole thing now as well..
Post #257577 9th Aug 2013 6:42pm
pjb
Hi Nick
What make as on my list of things to do one day Question 2020 P300 HSE
Post #257580 9th Aug 2013 6:46pm
Nick-St
It's the genuine LR one. The welding/finishing is a bit agricultural, some of the bolts aren't quite long enough to fully engage the nylon in the nylock nuts, & they supply 12mm bolts to fit through 10mm holes - but I suppose that's to be expected!!
Post #257583 9th Aug 2013 6:50pm
pjb
Standard land rover quality then 2020 P300 HSE
Post #257598 9th Aug 2013 7:52pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Looking good, this is also on my to do list Thumbs Up
Post #257653 9th Aug 2013 11:24pm
I fitted one to my ICE edition, good practical modification, I then fitted reversing sensors to the step
Nice to see a job well done!
Post #257674 10th Aug 2013 7:33am
Nick-St
Reversing sensors are on my to-do list as well...
Post #257676 10th Aug 2013 7:39am
Cheshire110
Whatever you do DON'T fit them straight into the crossmember! They will cause it to rust more quickly than you can say 'waxoyl'!
They can be fitted (just about) in the rear bumper, it'll have the same effect but at least it's an accessory not the x-member! Cheers, David
Post #257682 10th Aug 2013 8:21am
on the rear bumper step, i fitted a small plastic rectangle and mounted the sensors on the bottom edge, the top edge on the bumper step
Post #257690 10th Aug 2013 9:29am
Cheshire110
Interesting, sounds good! If you have any pics they would be much appreciated!
Saw a 110 with conpletely rotten rear Xmember due to parking sensors the other day, and it was a '59 plate! Shows what a difference it makes Cheers, David
Post #257692 10th Aug 2013 9:42am
