![]() | Home > Camping, Caravanning and Holidays > hammock hooks for 110 |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6005 ![]() ![]() ![]() |
Just an idea
Could you add an additional bracket to the front upper seat belt mount on either side so you can drop in a bar that goes across so you can attach one end of the hammock to that. For the rear a bar that is attached to the joint above the windows/below the roof and attach the rear hammock to there? Would the seat headrests take the weight of a hammock hanging off there? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
That's a good idea I'll look at the set up later
I have a thought that I could create a hook that bolts under the sun visor brackets and the rear do handles (above door) but not sure of there load capacity
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17852 ![]() ![]() ![]() |
I'd be uneasy about this. The sun visors was held (IIRC) by two M6 posi pan head set screws each, and although I can't comment on the rear handles I doubt that they're any more substantial than the visors. Given that a hammock, especially if it is tied tightly - almost taut - can exert very high loads on its mountings I doubt that this is viable. It may be you that goes bump in the night! Fit an internal cage? |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Have a look at Landiebox "www.landiebox.co.uk" as they have installed a hammock in a 110. It looks like they use eye bolts with chain link.
I have considered a cage but that's many pennies just to hang a hammock although a cage may be a future mod. I'll see how landing box have done it I thyouth the visors might not bolt onto very supportive brackets
