Home > Camping, Caravanning and Holidays > hammock hooks for 110
theorangebandit
I have had a search for a way to hang two hammocks length ways next to each other in my defender. However... I am struggling to locate an ideal point to mount the hooks that would take the load correctly. I know little about the roof support all the defenders I've hammocked up in before had cages internally and so was a breeze to set up and advice would be mmuch appreciated I know the topic has been touched before but I didn'. Find a solution
Post #254209 28th Jul 2013 9:12pm
excossack
Just an idea
Could you add an additional bracket to the front upper seat belt mount on either side so you can drop in a bar that goes across so you can attach one end of the hammock to that.
For the rear a bar that is attached to the joint above the windows/below the roof and attach the rear hammock to there?
Would the seat headrests take the weight of a hammock hanging off there? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #254345 29th Jul 2013 1:31pm
theorangebandit
That's a good idea I'll look at the set up later
Post #254357 29th Jul 2013 2:18pm
theorangebandit
I have a thought that I could create a hook that bolts under the sun visor brackets and the rear do handles (above door) but not sure of there load capacity
Post #254370 29th Jul 2013 2:48pm
I'd be uneasy about this. The sun visors was held (IIRC) by two M6 posi pan head set screws each, and although I can't comment on the rear handles I doubt that they're any more substantial than the visors.
Given that a hammock, especially if it is tied tightly - almost taut - can exert very high loads on its mountings I doubt that this is viable. It may be you that goes bump in the night!
Fit an internal cage?
Post #254376 29th Jul 2013 3:10pm
smb
Have a look at Landiebox "www.landiebox.co.uk" as they have installed a hammock in a 110. It looks like they use eye bolts with chain link.
Post #254382 29th Jul 2013 3:27pm
theorangebandit
I have considered a cage but that's many pennies just to hang a hammock although a cage may be a future mod. I'll see how landing box have done it I thyouth the visors might not bolt onto very supportive brackets
Post #254416 29th Jul 2013 4:51pm
