Home > Camping, Caravanning and Holidays > Alko/ball/drop late(?), etc.... help! |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Never had a worry about height issues when towing a caravan with the OEM tow pack using the bottom set of holes without the need for fitting a drop plate. I have used the standard Alko towball,Bradley pin hitch and I now use the Dixon Bate extended neck ball and pin hitch. The Dixon Bate hitch sits a lot higher than the other two tow balls but you would never know any difference when looking at the Puma and caravan when hitched up.
Alko tow ball. Click image to enlarge Bradley tow ball Click image to enlarge Dixon Bate tow ball Click image to enlarge Click image to enlarge As you can see the van sits level Click image to enlarge And the previous van was no different when hitched Click image to enlarge As to the electrics I chose to change to the new 13 pin connection as I also bought a 7 pin converter from here http://www.piktrailers.co.uk/webpage.asp?m...uctid=1251 which I use when towing any trailer with the older 7 pin connection. HTH Brian. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
12th Aug 2012 6:21pm |
azure111s Member Since: 19 Jul 2009 Location: North Wiltshire Posts: 55 |
Thanks Brian - very helpful!
I'll fit the Alko ball and ask dealer if I can hitch up a display 'van and see how it looks. Judging by yours, should be ok |
13th Aug 2012 11:54am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
If caravan has the Alko type hitch with the big handle and stabilising pads in the head you might have a small problem with how the spare wheel is mounted.
Dependent on tyre size, wheel on back door/swingaway wheel carrier etc the red Alko handle might foul on the spare wheel. Solution remove red handle if it occurs. Brendan |
15th Aug 2012 7:39pm |
I'd wondered about that too Brendan - thanks!
15th Aug 2012 8:13pm |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
Even easier solution open the door before raising the handle. 2010 Defender 110 Station Wagon, Santorini Black.
29th Jul 2013 12:29am |
