![]() | Home > Camping, Caravanning and Holidays > Alko/ball/drop late(?), etc.... help! |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Never had a worry about height issues when towing a caravan with the OEM tow pack using the bottom set of holes without the need for fitting a drop plate. I have used the standard Alko towball,Bradley pin hitch and I now use the Dixon Bate extended neck ball and pin hitch. The Dixon Bate hitch sits a lot higher than the other two tow balls but you would never know any difference when looking at the Puma and caravan when hitched up.
Alko tow ball. ![]() Click image to enlarge Bradley tow ball ![]() Click image to enlarge Dixon Bate tow ball ![]() Click image to enlarge ![]() Click image to enlarge As you can see the van sits level ![]() Click image to enlarge And the previous van was no different when hitched ![]() Click image to enlarge As to the electrics I chose to change to the new 13 pin connection as I also bought a 7 pin converter from here http://www.piktrailers.co.uk/webpage.asp?m...uctid=1251 which I use when towing any trailer with the older 7 pin connection. HTH Brian. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
azure111s Member Since: 19 Jul 2009 Location: North Wiltshire Posts: 55 ![]() |
Thanks Brian - very helpful!
I'll fit the Alko ball and ask dealer if I can hitch up a display 'van and see how it looks. Judging by yours, should be ok ![]() |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
If caravan has the Alko type hitch with the big handle and stabilising pads in the head you might have a small problem with how the spare wheel is mounted.
Dependent on tyre size, wheel on back door/swingaway wheel carrier etc the red Alko handle might foul on the spare wheel. Solution remove red handle if it occurs. Brendan |
I'd wondered about that too Brendan - thanks!
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 575 ![]() ![]() ![]() |
Even easier solution open the door before raising the handle. 2010 Defender 110 Station Wagon, Santorini Black.
