![]() | Home > Puma (Tdci) > do you use your clutch....? |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
so before you all bury your heads in your hands .....I'm not just about to moan about anything.
well so long as I can hurry up and write this before the urge to overwhelms me. ![]() just wondering - when I start the car sometimes the engine seems lively and eager to start up (as I would expect with a modern unit). this isn't always the case and I'd foolishly thought the reason its doesn't always seem eager to spin up might be related to the shoe dragging on the drum brake (clearly this cant' be the case). so to the clutch. who depresses the clutch when starting the car ![]() so is HE a muppet depressing the clutch when starting up or does it not matter. I've always done this on other cars. clearly I wouldn't dream of doing it on this one. do I need to go and have a word with him? ![]() Last edited by Caterham on 14th May 2015 9:32pm. Edited 1 time in total |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
I dip the clutch on every car I start
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
Depressing the clutch reduces the load on the engine (gearbox drag).
Can't say off the top of my head if I do or don't, I probably do ![]() ![]() ![]() |
thats exactly why I depress the clutch when starting - to reduce load etc.
just wondering tho if on the defender if it makes a difference having the clutch switch? |
I doubt there's a different starting strategy depending on whether the clutch is depressed or not
I do for the reasons stated. Steve.
Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131 ![]() ![]() ![]() |
I would need to check, but I think I read in the manual that it's to reduce the stress on the starter motor. And yes, I always depress it when starting.
AndyS Member Since: 18 Aug 2012 Location: London Posts: 597 ![]() ![]() ![]() |
The book says depress the clutch so yes, I depress it.
I had an RG500 that I couldn't get started at all, tried and tried but the engine wouldn't turn over (kick start). The shop owner came out and started it first kick, no issues at all. Turned out I was pulling in the clutch which disengaged the kick start, shop owner left it out and it started. ![]() |
I'm sure one of the cars I had previously suggested you shouldn't.....I still did.
presumably the ecu / clutch switchy thing doesn't come into play when starting the engine - or at least it makes no difference? |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Habit for me, as I always leave it in gear (the hand brake is cack
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
I always start a manual vehicle with the clutch in
![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
i always depress the clutch in any vehicle fitted with one. Cheers
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
I always depress the clutch when starting or stopping the engine, force of habit.
I also always leave cars in gear. In a peculiarly old-fashioned way I also point the wheels at the kerb when parking on a hill, like we used to be taught to do back in the, er, seventies, when I took my test! |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1279 ![]() ![]() |
I always put the clutch in....more for safety than anything.
good habit to get into. Helps when other car (a BMW) wont start untill clutch is in Now BMW know a thing or two about engines..so it cant be a bad thing Clemmo |
