![]() | Home > Puma (Tdci) > do you use your clutch....? |
| Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200
Same here, always depress clutch starting engine on all manual vehicles.
Always park car in gear too. |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
interesting.....
I'll pop next door and tell him he's fine to continue depressing the clutch then Last edited by Caterham on 14th May 2015 8:35pm. Edited 1 time in total |
| schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378
Yes I always press the clutch pedal when starting, always have done this, as far as I can remember with all manual vehicles I have driven, and like some others I always leave in gear when parked up.
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Quite a lot of agricultural and plant machines need the clutch depressed when starting to open the starter inhibitor switch. I have allways put the clutch down on everything, if it has one, to start.
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
plus 1
All the stuff I start requires clutch down to start |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
I always press the clutch too. As said, old agricultural stuff I used to drive needed it, and my old motorbike needed the clutch lever pulled in.
Often park in gear (as well as the handbrake) so it's just second nature. better IMO to do that than assume that the vehicle is in neutral. yes, i know you only need to check the gearstick, but things can get knocked/pulled etc. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18048
I think the old classic confusion is creeping into some of these replies.
When the clutch is IN it is engaged When the clutch is OUT it is disengaged. |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
Copied from Owners Handbook.
1. Insert the black key into the starter switch and turn to position II. 2. Wait until the glow plug warning indicator extinguishes. The waiting time will vary according to engine temperature. 3. Fully depress the clutch pedal and turn the starter switch to position III to operate the starter motor. Release the key as soon as the engine starts. If the engine stalls or fails to start, you must return the starter switch to position I before attempting to restart.
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
| lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412
SWMBO's FL2 won't start unless the clutch pedal is depressed. I believe this is a feature of many cars but not the Defender? 1970 Series 2A 88"
| Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756
+23
everything I have ever driven gets started with clutch pedal depressed. Some need it due to inhibitor switches, others need it as they have been left in gear, and others need it due to marginal starting ability so far less load on the started when not turning at least some of a cold gearbox. |
I think that kind of answers that then - thanks for the responses
| All times are GMT |
