Home > Puma (Tdci) > do you use your clutch....?
Page 2 of 2 <12
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
Same here, always depress clutch starting engine on all manual vehicles.
Always park car in gear too.
Post #253016 22nd Jul 2013 1:37pm
landybehr
I think I neednīt bother. The RRC has an automatic gearbox (just joking), but with the Defender I do not depress the clutch at cranking.
Years ago I started thinking about the thrust bearing of the crankshaft which limits itīs axial movement. It is the only device, I think, which has to work against the forces which apply to the flywheel once the clutch slave cylinder somehow pushes against it. At cranking speeds you donīt have a proper oil pressure to help the bearing. So while I always park in gear, forgetting about a parking branke, I always go into neutral when cranking. But I wouldnīt dare to say that my engine/bearings will really live longer than anyone elseīs.
Post #253017 22nd Jul 2013 1:38pm
Caterham
interesting.....
I'll pop next door and tell him he's fine to continue depressing the clutch then Whistle
Post #253018 22nd Jul 2013 1:40pm
schuee
Yes I always press the clutch pedal when starting, always have done this, as far as I can remember with all manual vehicles I have driven, and like some others I always leave in gear when parked up.
Post #253028 22nd Jul 2013 2:13pm
JWL
Quite a lot of agricultural and plant machines need the clutch depressed when starting to open the starter inhibitor switch. I have allways put the clutch down on everything, if it has one, to start.
Post #253029 22nd Jul 2013 2:24pm
plus 1
All the stuff I start requires clutch down to start
Post #253033 22nd Jul 2013 2:46pm
I always press the clutch too. As said, old agricultural stuff I used to drive needed it, and my old motorbike needed the clutch lever pulled in.
Often park in gear (as well as the handbrake) so it's just second nature. better IMO to do that than assume that the vehicle is in neutral.
yes, i know you only need to check the gearstick, but things can get knocked/pulled etc.
Post #253038 22nd Jul 2013 3:17pm
I think the old classic confusion is creeping into some of these replies.
When the clutch is IN it is engaged
When the clutch is OUT it is disengaged.
Post #253042 22nd Jul 2013 3:53pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Copied from Owners Handbook.
1. Insert the black key into the starter switch and turn to position II.
2. Wait until the glow plug warning indicator extinguishes. The waiting time will vary according to engine temperature.
3. Fully depress the clutch pedal and turn the starter switch to position III to operate the starter motor. Release the key as soon as the engine starts.
If the engine stalls or fails to start, you must return the starter switch to position I before attempting to restart.
Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #253044 22nd Jul 2013 4:24pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
SWMBO's FL2 won't start unless the clutch pedal is depressed. I believe this is a feature of many cars but not the Defender? 1970 Series 2A 88"
Post #253045 22nd Jul 2013 4:28pm
Mountain_man
Wales
+23
everything I have ever driven gets started with clutch pedal depressed. Some need it due to inhibitor switches, others need it as they have been left in gear, and others need it due to marginal starting ability so far less load on the started when not turning at least some of a cold gearbox.
Post #253056 22nd Jul 2013 5:48pm
Caterham
I think that kind of answers that then - thanks for the responses Thumbs Up
Post #253085 22nd Jul 2013 8:11pm
Page 2 of 2 <12
