![]() | Home > Maintenance & Modifications > 110 Double Cab TD5 Anti Roll Bar |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 430 ![]() ![]() ![]() |
I brought a full terrafirma anti rool bar kit, this is normally where you already have them and you want them stiffer so you will have to buy all the bushes and chassis clamps seperately. It has made an unbelieveble difference, with my new slick tyres running on 18 boosts, i can handle it like a golf gti. I have also lowered mine and got stiffer springs so that helps as well, but fitting a full kit of anti roll bars is the best option, dont gor for a cheap 'complete set' from paddock or anywhere like that coz i did at first, and on the first axel twist, the rear bbent like a bloody banana. Will set you back about £600 qwid and takes about 2/3 hours to fit but will transform the ride and cornering of your landy.
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Been thinking about one of these http://www.x-eng.co.uk/StoreDisplay.asp?MID=2&SL=73 anyone got one fitted?
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
If fitting the x-eng arb, should a front arb be fitted also ?
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 811 ![]() ![]() |
In my opinion - yes A good starting point is a pair of standard anti roll bars with uprated mounts. If you decide that you still want more roll control, then I would fit an uprated rear one (25.4mm). Again with uprated mounts. Standard bars make a good difference on a none roll bar equipped Defender, but a uprated rear one makes it better again. However, it will limit articulation if used off road. I can supply all parts if needed. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6180 ![]() ![]() ![]() |
Ian, what are upgraded mounts? where they bolt onto the chassis? or axle end? better ball joints?
Is there any difference between Discovery 1 and Defender anti-roll bars? I have heard you can simply fit D1 roll bars to a Defender...
Won't the chassis rails be further apart (wider) on a D1 than a Defender?
D1 axles fit onto a defender, and vica versa, so I'd say not. I've got an ex disco1 front A/R bar on my 90.... bolted straight on. |
Every days a school day! Porny when you say upgraded mounts do you mean the ARB bushes?
Any idea on what these upgraded mounts are or what they look like?
Still going to fit ARBs to the "Miffster", 2002 110... |
Hi Tom, Did you fit an ARB set in the end? if so what did you go for? And was it worth it? |
Tom DCab Member Since: 13 Jun 2013 Location: West Sussex Posts: 33 ![]() ![]() ![]() |
Hi Geobloke
Yes, I bought a complete kit with polyurethane bushes from Paddock - STC8156AAPY Cost £168 incl vat & delivery Fitted them myself very easily...took a couple of hours.. I noticed straight away after fitting them that there was much less roll when cornering and that it now turns in to corners more precisely. The ride over bumps has not stiffened as far as I can tell. I am pleased with results and I think it is well worth doing. I dont do much off roading so I am not too bothered if there is slightly less axle articulation as a result of fitting these. Hope that helps! Tom |
Superb thank you Tom for the update. I like you am not an "extreme" off roader, although I do enjoy green laning and overlanding my 110. At the moment I have Gwyn Lewis' extreme suspension kit on the 110 and as good as that is and it is superb it is just not what I need anymore. So I am going to return the vehicle to standard height springs, uprated shocks (probably Bilstein, OME or Koni) and of course a set of ARBs. With all the gear in the back the 110 leans quite a lot in the corners although not dangerously. When driving the mountain roads of the Pyrenees a little extra stiffness in the corners would have been nice...
Showing as out of stock but will not fit Puma anyway - says kit under development...would be nice to know if/when... |
