![]() | Home > Puma (Tdci) > Rear diff guards |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 846 ![]() ![]() ![]() |
Fitted a QT guard and got it from Cheviot 4x4 - 0191 2574444
Russell. |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Thanks for that will try and get one
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Mines fitted with one from OEC http://www.oec4x4.com/
Bit of a tight fit !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
dave's 110 Member Since: 11 Jun 2008 Location: Norfolk Posts: 45 ![]() ![]() ![]() |
Why you need one as the Puma has a 6mm welded in diff pan fitted already ?
Dave |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5111 ![]() ![]() ![]() |
Having seen the damage a rock can do - you always need them Mike
Every little helps
Yep,, extra piece of mind
![]() ![]() Main Brian James Trailer Dealer for South West UK |
Always need protection! Alot cheaper than sorting out the mess a rock has caused, spent all weekend avoiding large rocks in wales, 110 did really well, no water leaks from the front doors was a plus!.
AndrewW Member Since: 25 Nov 2009 Location: saddleworth Posts: 34 ![]() ![]() |
Does anyone have advice on diff guards from the point of view of mud collection -> corrosion of the "tinny" diff casing by trapped mud?
Is there an "open" guard? i.e. made of bar elements rather than a mud-trapping plate? Need to fit 12 ![]() Andy Carefully going everywhere |
Why should there be a problem?
Have had two fitted on the 110 overland vehicle for years without problems. Get your vehicle clean, waxoyl it. Then put protection on. Clean it occasionally and waxoyl every 2/3 years. Just be careful about some of the aftermarket diff guards. The ones we use and supply are made in Yorkshire from 8mm galvanised steel. There again another company will sell you 2 for £25. Must be made from far eastern tin foil ![]() HTH Brendan |
Search button and "diff guards" reveals...... http://www.defender2.net/forum/topic2837.h...iff+guards http://www.defender2.net/forum/topic2093.h...iff+guards http://www.defender2.net/forum/topic1904.h...iff+guards http://www.defender2.net/forum/topic1850.h...iff+guards More on there as well.... ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Do Tescos sell 'em too then????? ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8359 ![]() ![]() ![]() |
i fitted a Southdown P38 rear diff guard. Cheers
