Home > Puma (Tdci) > Rear diff guards
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Rear diff guards
Anyone fitted a rear diff guard to a puma, if so what make and where did you get it from?
Mark
Post #2460 18th Jun 2008 9:12am
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Fitted a QT guard and got it from Cheviot 4x4 - 0191 2574444
Russell.
Post #2461 18th Jun 2008 12:10pm
markalpha
Thanks for that will try and get one
Post #2464 18th Jun 2008 1:50pm
TJ101
Mines fitted with one from OEC http://www.oec4x4.com/
Bit of a tight fit !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #2483 19th Jun 2008 6:30pm
dave's 110
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Stornoway Grey
Why you need one as the Puma has a 6mm welded in diff pan fitted already ?
Dave
Post #2496 20th Jun 2008 7:53pm
mse
Having seen the damage a rock can do - you always need them Mike
Post #2500 21st Jun 2008 9:50am
Happyoldgit
Every little helps Smile
Post #2518 22nd Jun 2008 11:47am
TJ101
Yep,, extra piece of mind Whistle will post up some pics of the OEC one, when i get back Thumbs Up California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #2519 22nd Jun 2008 12:10pm
markalpha
Always need protection! Alot cheaper than sorting out the mess a rock has caused, spent all weekend avoiding large rocks in wales, 110 did really well, no water leaks from the front doors was a plus!.
Post #2530 23rd Jun 2008 4:20pm
AndrewW
Does anyone have advice on diff guards from the point of view of mud collection -> corrosion of the "tinny" diff casing by trapped mud?
Is there an "open" guard? i.e. made of bar elements rather than a mud-trapping plate?
Need to fit 12 Mr. Green on 6 Mountain Rescue 110s
Andy Carefully going everywhere
Post #30947 28th Apr 2010 12:03pm
leeds
Why should there be a problem?
Have had two fitted on the 110 overland vehicle for years without problems. Get your vehicle clean, waxoyl it. Then put protection on. Clean it occasionally and waxoyl every 2/3 years.
Just be careful about some of the aftermarket diff guards. The ones we use and supply are made in Yorkshire from 8mm galvanised steel. There again another company will sell you 2 for £25. Must be made from far eastern tin foil Laughing
HTH
Brendan
Post #30951 28th Apr 2010 1:11pm
K9F
Re: Rear diff guards
Search button and "diff guards" reveals......
http://www.defender2.net/forum/topic2837.h...iff+guards
http://www.defender2.net/forum/topic2093.h...iff+guards
http://www.defender2.net/forum/topic1904.h...iff+guards
http://www.defender2.net/forum/topic1850.h...iff+guards
More on there as well....
Thumbs Up Thumbs Up Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30952 28th Apr 2010 2:18pm
K9F
Do Tescos sell 'em too then?????
Rolling with laughter Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30955 28th Apr 2010 2:37pm
jst
i fitted a Southdown P38 rear diff guard. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #30999 29th Apr 2010 6:28am
