![]() | Home > Puma (Tdci) > odd question |
solmanic Member Since: 17 Aug 2007 Location: Brisbane Posts: 191 ![]() ![]() ![]() |
Mine just had the common rail system replaced. Got what I thought was a spurious engine warning light with a momentary loss of power then all fine. Took it straight to the dealer and they plugged in, recorded the fault, sent it to LR, got the word back - change the common rail. I haven't noticed anything untoward in my fuel economy (28mpg consistenly since new). But then again, I haven't used a full tank since they did the job to know if there's any improvement. I was also getting some oddness just after start-up, about 60 seconds after moving off there would be a peculiar revving then fine. Again, I haven't noticed this happening since the work was done but it wasn't all that often. 2007 Defender 110 1970 Alfa Romeo 1750GTV |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 831 ![]() ![]() ![]() |
Solmanic seams I am having the same problem as you, sounds like its running on 3 cylinders for a few seconds on start up from cold and then runs fine . Did you notice any flat spots around 2000 revs ? Glad you got yours sorted. Nidge. |
No - my funny engine revs thing was not like a mis-fire at all. It was as if the clutch was disengaged and the engine seemed to over-rev for a few seconds (but unlike the gear-change, revving issue reported elsewhere).
Never noticed a flat spot. There was only the momentary loss of power the day the engine light came on then everything went back to normal. I couldn't tell you what revs it was at because it only happened once. 2007 Defender 110 1970 Alfa Romeo 1750GTV |
