![]() | Home > Puma (Tdci) > Where did you mount your Amature Radio Gear |
| JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532
06.39 post, you're keen!
I'm M3OJR up here in Fife. I'm planning on putting mine below the cubby box spacering the box as necessary. I've seen it done in a friend's 300 and there doesn't seem to be any heat problems from the transmission. Also he removed the wooden spacer brackets and replaced them with ally ones and rear hinged the whole thing for quick access. It works well and the extra height makes the cubby more useable as an armrest. |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
If you hinge at the rear, doesn't the cubby crash into the rear bulkhead on a 90..? (I note Swallock has a 110 so shouldn't be a problem for him).
cheers simon |
True but our Tdci is a 110.
My 90, being an original 1984 motor has the radio screwed to the main panel above the fuse box and in front of the gearstick ( that radio doesn't have a demountable front). I could still hinge the cubby though as I have a Mud 4x4 bulkhead delete kit which removes the vertical part of the bulkhead. |
Ah, ok..
cheers simon |
| ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 575
I'm in the same boat, I have a Kenwood 2m/70cm rig with a seperation kit, I thought perhaps put the main part of the set in the cubby box (it's not very big) and mount the head on a gooseneck type stalk bolted to the passenger side of the transmission tunnel, but I like the idea of raising the cubby box JR, very cunning!
Chris 2010 Defender 110 Station Wagon, Santorini Black. |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6042
Mine is the on the front of the Cubby box, but mine is a TD5.
M6JPE is my call sign. JR: - In Scotland would you not be MM3OJR ? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
There is some pics here of a standard LR cubby that we raised the floor in to allow space for equipment underneath
http://www.defender2.net/forum/topic21121.html Alternatively we manufacture the worlds only Double DIN cubby box http://www.farrowsclassics.co.uk/fcx--Twin-DIN--cubby.html |
John: Yes, it's MM3 in Scotland but I was thinking of you guys in that other place where it would be M3.
| zs1sam Member Since: 21 Jun 2013 Location: Cape Town Posts: 30
Greetings to all from Simonstown, South Africa
I'm in the process of installing an Icom 7000 into my 110 Puma (station wagon). As it will not be a pemanent installation the intention is to mount the radio on the rear panel of the centre glove box ie the one between the 2 front seats. I've been told that I can expect a lot of electronic intererence on HF. would anyone care to comment with their experience and hopefully how to overcome the problem (if it exists)? Cheers Sam ZS1SAM www.sammnet.com |
| Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285
Thanks for all the replies, it would seem that some form of cubby box conversion is the preferred method of mounting, guess it also gives easy access to power and routing options for the remote head cable. My only worry would be the heat that a 706 can put out even when just switched on.
Sam if you mount it on the rear panel of the Cubby would that be on the outside, and if so would that not leave it exposed to kids in the rear giving the odd kick. 2008 Defender 110 XS CSW Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
Fortunately both my "kids" are over 30! and they both have their own 4x4's!! If and when grand-children arrive on the scene, I'll tie them on the roof-rack! My concern of actually concealing the body of the IC 7000 is that it generates a lot of heat (more than the 706).
I should be installing the radio this weekend after fixing the ball-mount for Hustler antennas on the side of the roof-rack. Hopefully the roof-rack or the ladder will provide sufficient earthing. 73 Sam |
