Home > Puma (Tdci) > Where did you mount your Amature Radio Gear
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
As a keen Radio Ham as well as Landrover nut I had my Icom 706 mounted under the rear seat in the 300TDI 110 County with the display remote mounted on the dash. The 300 has gone and now that I have gone Puma, also 110 county, I now have that age old question where best to fit the radio and aerial mounting options.
I would be interested in suggestions or pictures of where you put yours.? 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #247547 29th Jun 2013 6:39am
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
06.39 post, you're keen!
I'm M3OJR up here in Fife.
I'm planning on putting mine below the cubby box spacering the box as necessary. I've seen it done in a friend's 300 and there doesn't seem to be any heat problems from the transmission. Also he removed the wooden spacer brackets and replaced them with ally ones and rear hinged the whole thing for quick access. It works well and the extra height makes the cubby more useable as an armrest.
Post #247566 29th Jun 2013 9:21am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
If you hinge at the rear, doesn't the cubby crash into the rear bulkhead on a 90..? (I note Swallock has a 110 so shouldn't be a problem for him).
cheers
simon
Post #247576 29th Jun 2013 10:15am
JR
True but our Tdci is a 110.
My 90, being an original 1984 motor has the radio screwed to the main panel above the fuse box and in front of the gearstick ( that radio doesn't have a demountable front). I could still hinge the cubby though as I have a Mud 4x4 bulkhead delete kit which removes the vertical part of the bulkhead.
Post #247579 29th Jun 2013 10:24am
couplands
Ah, ok..Wink Thought you had come up with a cunning hinge arrangement..!
cheers
simon
Post #247581 29th Jun 2013 10:26am
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
I'm in the same boat, I have a Kenwood 2m/70cm rig with a seperation kit, I thought perhaps put the main part of the set in the cubby box (it's not very big) and mount the head on a gooseneck type stalk bolted to the passenger side of the transmission tunnel, but I like the idea of raising the cubby box JR, very cunning!
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #247618 29th Jun 2013 6:01pm
excossack
Mine is the on the front of the Cubby box, but mine is a TD5.
M6JPE is my call sign.
JR: - In Scotland would you not be MM3OJR ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #247678 29th Jun 2013 9:29pm
There is some pics here of a standard LR cubby that we raised the floor in to allow space for equipment underneath
http://www.defender2.net/forum/topic21121.html
Alternatively we manufacture the worlds only Double DIN cubby box
http://www.farrowsclassics.co.uk/fcx--Twin-DIN--cubby.html
Post #247719 30th Jun 2013 8:44am
JR
John: Yes, it's MM3 in Scotland but I was thinking of you guys in that other place where it would be M3. Laughing
Post #247763 30th Jun 2013 1:20pm
zs1sam
South Africa 2011 Defender 110 Puma 2.4 SW Alpine White
Greetings to all from Simonstown, South Africa
I'm in the process of installing an Icom 7000 into my 110 Puma (station wagon). As it will not be a pemanent installation the intention is to mount the radio on the rear panel of the centre glove box ie the one between the 2 front seats. I've been told that I can expect a lot of electronic intererence on HF. would anyone care to comment with their experience and hopefully how to overcome the problem (if it exists)?
Sam
ZS1SAM
www.sammnet.com
Post #247810 30th Jun 2013 5:38pm
Swollock
Thanks for all the replies, it would seem that some form of cubby box conversion is the preferred method of mounting, guess it also gives easy access to power and routing options for the remote head cable. My only worry would be the heat that a 706 can put out even when just switched on.
Sam if you mount it on the rear panel of the Cubby would that be on the outside, and if so would that not leave it exposed to kids in the rear giving the odd kick. 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #248012 1st Jul 2013 1:36pm
zs1sam
Fortunately both my "kids" are over 30! and they both have their own 4x4's!! If and when grand-children arrive on the scene, I'll tie them on the roof-rack! My concern of actually concealing the body of the IC 7000 is that it generates a lot of heat (more than the 706).
I should be installing the radio this weekend after fixing the ball-mount for Hustler antennas on the side of the roof-rack. Hopefully the roof-rack or the ladder will provide sufficient earthing.
73
Sam
Post #248029 1st Jul 2013 2:58pm
