Home > Puma (Tdci) > Central locking / Alarm
louiskemp1
Just picked up my defender today and done 100 miles in it just cruising around Razz
So far so good, apart from my only query is do all puma defenders have central locking or is this an optional extra? (mines a 13 plate btw) I thought mine would have it but on the key when i press lock, nothing happens apart from a flash of the orange lights, i can open the door after this but the alarm goes off. This means the only way for me to lock the door is with the actual key, but i read that this disables the alarm also in the manual.
Also the defender driver waves to each other give me a Mr. Green every time!
Thanks, louis Thumbs Up
Post #246738 25th Jun 2013 9:41pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Something wrong with your lock motors - its supposed to lock the doors when you press that button and orange lights flash. Take it back to the dealer to sort out
Post #246806 25th Jun 2013 11:02pm
louiskemp1
yeah thats what i thought, just wasnt sure if it did actually have central locking or not and i just had the key for it
Post #246821 25th Jun 2013 11:15pm
JWL
If your key makes all the doors lock/unlock then you have central locking and it might be that it hasn't been "turned on" to work with the fob. Putting the motor on the diagnostics will soon sort it, job for the dealer with a bit of a gripe at them on their PDI standards.
Post #246823 25th Jun 2013 11:29pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I think it depends on the model. IIRC the base models don't have central locking, only the alarm. Have a look at the landrover web site, or the brochure.
My HT only had the alarm, and the central locking was fitted as an after-market add-on.
Simon
Post #246826 25th Jun 2013 11:47pm
louiskemp1
Simon
Yeah it says that the central locking is an optional extra, but would they give me the key fob with the unlock/lock buttons if it didnt have it?
Post #246827 25th Jun 2013 11:59pm
couplands
The fob locks/unlocks the alarm, so I guess it's the same fob if you have/have not the central locking...it is on mine...
Simon
Post #246828 26th Jun 2013 12:02am
JWL
You need the fob really as it contains the gadget that works the immobiliser, it needs to be in close proximity of the ignition switch to not trigger the immobiliser to stop you working the Defender.
Post #246829 26th Jun 2013 12:10am
Retroanaconda
Yep central locking is optional. Fob is for the alarm/immobiliser (as fitted). Also works central locking if fitted.
Just remember to lock the doors when you get out. Caught me out when I first used the 130 at work as my own 90 had had CDL for years.
Post #247081 26th Jun 2013 10:44pm
Porny
Site Sponsor
Its not a major task to fit central locking if needed....
Just make sure you use all genuine parts!
You need the central locking actuators, new 10AS alarm module, and an overlay wiring harness and correct plugs/pins.
This means it looks standard, and any spare parts are off the shelf.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #247134 27th Jun 2013 9:30am
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Why the hell is central locking an option??? It must be the only new car in the world that it isn't standard on. Certainly the only vehicle in the JLR group! Can you imagine even a Freelander without central locking. JLR amaze me sometimes!
Post #247136 27th Jun 2013 9:40am
Porny
Site Sponsor
My 2010 poverty spec Hard Top Puma came with no central locking and no stereo....
Bit different to my 1955 Series One though - that doesn't have any comforts. Even the passenger windscreen wiper was an option!
Ian IRB
Post #247182 27th Jun 2013 12:27pm
pjb
�375 option for elec windows & central locking, if its got electric windows then should have central locking.
Hope that helps Thumbs Up 2020 P300 HSE
Post #247185 27th Jun 2013 12:38pm
louiskemp1
Yeah i dont think it has central locking, i keep forgetting to turn off the alarm before unlocking the doors though Big Cry ha
Post #247190 27th Jun 2013 12:56pm
kmac
If the driver door key locks all doors then it has central locking (but not necessarily remote central locking)
If the fob also locks all doors it has remote central locking.
If the drivers key only locks the drivers door, then sadly no central locking.
I thought only cars over 15 years old didn't have central locking.
Post #247219 27th Jun 2013 3:52pm
