![]() | Home > Puma (Tdci) > Central locking / Alarm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Something wrong with your lock motors - its supposed to lock the doors when you press that button and orange lights flash. Take it back to the dealer to sort out
louiskemp1 Member Since: 19 Mar 2013 Location: Norfolk Posts: 55 ![]() ![]() |
yeah thats what i thought, just wasnt sure if it did actually have central locking or not and i just had the key for it
If your key makes all the doors lock/unlock then you have central locking and it might be that it hasn't been "turned on" to work with the fob. Putting the motor on the diagnostics will soon sort it, job for the dealer with a bit of a gripe at them on their PDI standards.
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
I think it depends on the model. IIRC the base models don't have central locking, only the alarm. Have a look at the landrover web site, or the brochure.
My HT only had the alarm, and the central locking was fitted as an after-market add-on. Cheers Simon |
Yeah it says that the central locking is an optional extra, but would they give me the key fob with the unlock/lock buttons if it didnt have it? |
The fob locks/unlocks the alarm, so I guess it's the same fob if you have/have not the central locking...it is on mine...
Cheers Simon |
You need the fob really as it contains the gadget that works the immobiliser, it needs to be in close proximity of the ignition switch to not trigger the immobiliser to stop you working the Defender.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2750 ![]() ![]() |
Yep central locking is optional. Fob is for the alarm/immobiliser (as fitted). Also works central locking if fitted.
Just remember to lock the doors when you get out. Caught me out when I first used the 130 at work as my own 90 had had CDL for years. |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Its not a major task to fit central locking if needed....
Just make sure you use all genuine parts! You need the central locking actuators, new 10AS alarm module, and an overlay wiring harness and correct plugs/pins. This means it looks standard, and any spare parts are off the shelf. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Why the hell is central locking an option??? It must be the only new car in the world that it isn't standard on. Certainly the only vehicle in the JLR group! Can you imagine even a Freelander without central locking. JLR amaze me sometimes!
My 2010 poverty spec Hard Top Puma came with no central locking and no stereo....
Bit different to my 1955 Series One though - that doesn't have any comforts. Even the passenger windscreen wiper was an option! Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
�375 option for elec windows & central locking, if its got electric windows then should have central locking.
Hope that helps ![]() |
Yeah i dont think it has central locking, i keep forgetting to turn off the alarm before unlocking the doors though
If the driver door key locks all doors then it has central locking (but not necessarily remote central locking)
If the fob also locks all doors it has remote central locking. If the drivers key only locks the drivers door, then sadly no central locking. I thought only cars over 15 years old didn't have central locking. |
