![]() | Home > Td5 > Saving ecu map on nanocom as ".map" file |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
It cannot be done, Hugh, as tuned nanocom files are encrypted and locked to your vehicle.
If you can read your .tun file, then you've got a backup which can be re-applied to your car as many times as you like. If you need any further assistance, feel free to give me a call or drop me an email. |
hugh_b Member Since: 15 Sep 2010 Location: Kent Posts: 75 ![]() |
Thanks Gary. I was under the impression I needed a .map file as a backup. I have the .tun file saved on my laptop.
Thanks Hugh |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6197 ![]() ![]() ![]() |
Sorry to hijack the thread...
Gary, are saying then, if i were to take a .tun file image of my ECU, this would be a complete "backup" of it, alarm settings/engine tune file/etc all in one? would this include any modified tune file as well? cheers |
It would be a complete backup of the engine ECU calibration maps and software only. Configuration data such as Immobiliser code, Injector grades, Throttle type, etc are not stored within the .map or .tun files, but can be saved separetly. Each .map or .tun file will hold one set of ECU calibration data only. |
Cheers for that
![]() so, being dim here....I assume calibration maps to be the "tune" file... i.e. standard or go faster? |
Correct. ![]() |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
If i want to backup my mappings and try another stage1 map, how/what do i backup first with the nanocom evolution ?
This is a 1998 TD5 with a replacement 000120 ECU Thanks JD 2008 TDCi 2.4 XS CSW |
Simply read the map file from the ecu, and Nanocom will save it as a .map or .tun file onto the SD card. You can then program whatever you like onto your ecu, and when you're done, and you want to re-install your saved map, simply select to write map file, or write tuning map file back onto the ecu.
Td5 can be immensely unreliable at programming, and so don't flash the ecu any more times than you need to. |
Many Thanks
Is there a risk of trashing the ECU then ? 2008 TDCi 2.4 XS CSW |
Very much so! ![]() If your ecu does die during programming, you can send it into us and we can revive it, and apply your tuning map as well. Regards, Gary. |
Hi Gary
Yikes .....Now I'm scared...... Its not the original ECU as mine would have been an NNN (1998) it has been replaced at some point with a 000120, does that make it any better or worse Gary ? JD 2008 TDCi 2.4 XS CSW |
Your original ECU would have had an MSB part number, possibly an MSB101170, which Land Rover could well have replaced as a recall. There is no real difference in the way the engine would run between an MSB and a NNN ecu, assuming it has the correct software programmed onto it.
If I try and backup the ecu map it comes up with a blank 'select folder' window.....I can't seem to do anything from that point, if I select continue, the backup starts then fails, any ideas anyone? Do I need some sort of folder structure?
If you go to the nanocom website, you can view the evo manual on line, or right-click this link ----> and download it to your PC or download links for instructional evo videos
