Home > Puma (Tdci) > Rattle in transmission tunnel
Cracka
2012 Defender 90 Puma 2.2 HT Fuji White
Well I went out yesterday scoping out a new area to collect firewood. It was pretty steep and I was using 1st 2nd 3rd low range for a part of it. I found when under a bit of load about 1250 rpm I get a rattle from the transmission tunnel area that disappears at 1500 rpm. I'm not being OCD with this one its pretty loud.
Has anybody had this or have any ideas.
Post #245055 20th Jun 2013 9:45am
Norm4n
Mine always sounds like that in low range
Post #245103 20th Jun 2013 1:44pm
Cracka
Do you know what causes it ?
Post #245225 20th Jun 2013 10:37pm
Caterham
have you checked the exhaust manifold heat shield or support bracket isn't loose?
Post #245258 21st Jun 2013 7:42am
Naks
sounds like the clutch, they all do this to a lesser-bigger degree --
Post #245286 21st Jun 2013 9:31am
Cracka
Thanks for the replies guys.
I checked all heat shield and drive shaft flange bolts front and rear today, they were fine.
I did find a loose bolt at the front of the seatbox, drivers side against the transmission tunnel which bolts to a bracket on the chassis. This I'm hoping was the culprit.
I also found when the Hi Lo selector is in low range the retaining clip at the bottom of the pivot arm actually contacts a bolt head on top of the transfer case. Not sure if this could make the sound I could hear, though anything's possible.
Well I took the car to a hill (on bitumen near home) tried it in low range and got no rattly noises Very Happy . I can't see that if would be any different off road but will see next week when off road again.
Naks, if it was the clutch would it do it in high range as well ?
Post #245291 21st Jun 2013 9:47am
Naks
Yep, but to a lesser extent. I idle in first when leaving home, it does it only when trying to go over the speed bumps in the driveway, so when it pushes out lots of torque.
Even when I got a new clutch installed, it did this when we went off road. --
Post #245294 21st Jun 2013 9:50am
Cracka
Thanks buddy, you were quick.....
I actually have a bit of a steep driveway from the street kerb up into the garage and I normally just ease off the clutch (high range) and let the car idle up the drive in either first or reverse using the anti stall and haven't heard it so hopefully Whistle it won't be the clutch.
Post #245299 21st Jun 2013 10:09am
