![]() | Home > Puma (Tdci) > Rattle in transmission tunnel |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Mine always sounds like that in low range
Cracka Member Since: 08 Dec 2012 Location: New South Wales, Australia Posts: 129 ![]() ![]() |
Do you know what causes it ?
have you checked the exhaust manifold heat shield or support bracket isn't loose?
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
sounds like the clutch, they all do this to a lesser-bigger degree --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Thanks for the replies guys.
I checked all heat shield and drive shaft flange bolts front and rear today, they were fine. I did find a loose bolt at the front of the seatbox, drivers side against the transmission tunnel which bolts to a bracket on the chassis. This I'm hoping was the culprit. I also found when the Hi Lo selector is in low range the retaining clip at the bottom of the pivot arm actually contacts a bolt head on top of the transfer case. Not sure if this could make the sound I could hear, though anything's possible. Well I took the car to a hill (on bitumen near home) tried it in low range and got no rattly noises ![]() Naks, if it was the clutch would it do it in high range as well ? |
Yep, but to a lesser extent. I idle in first when leaving home, it does it only when trying to go over the speed bumps in the driveway, so when it pushes out lots of torque. Even when I got a new clutch installed, it did this when we went off road. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Thanks buddy, you were quick.....
I actually have a bit of a steep driveway from the street kerb up into the garage and I normally just ease off the clutch (high range) and let the car idle up the drive in either first or reverse using the anti stall and haven't heard it so hopefully ![]() |
