Home > Maintenance & Modifications > Steering Guard
Page 2 of 2 <12
SGH
I went for an ali one and got it powder coated.
Post #244926 19th Jun 2013 8:35pm
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
K9F wrote:
Not Terrafirma.....First Four.
http://www.firstfour.co.uk/item/714342/def...ent-bumper
Sorry to be thick but how do the recovery points fasten or were they optional add ons to the bumper?
I have an svx-fronted 110 with standard bumper. I want to put my a-bar back on because I think they look great and when I have saved up might dangle some extra lights from it but am not sure about what to do for front recovery point. JATE rings are a PITA to get to. So maybe get a steering guard with recovery points but I like your set up.
TIA
Craig 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #244949 19th Jun 2013 9:31pm
mrandmrsh
Ahh sorry have looked at FF bumper as used by K9F on ipad rather than phone and can see recovery points. Very nice and under stated. Thumbs Up 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
Post #244952 19th Jun 2013 9:39pm
K9F
The recovery points are actually welded as part of the manufacturing process to the bumper. Due to the close fitting of the SXV style steering guard and the cutouts on the top edge it will not fit with the recovery eyes (the cutouts can be seen clearly in BPman's picture). I had to take an angle grinder to the guard and take off about a 2" X 1" piece either side where the eyes are. My guard was already looking tired so I then had it powder coated black and it fitted perfectly. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #244955 19th Jun 2013 9:43pm
keith
I think killer is working on a new aluminium guard . Due for sale sooon I believe .
Post #244959 19th Jun 2013 9:48pm
leeds
What happens when you buy cheap steering guards
[/URL][/img]
If something is cheap there is normally a good or should that be a bad reason for it.
Changing subject slightly.
Shackles of the same pin diameter.
In general terms stainless has a lower rating then galvanised steel.
Dee shackles are normally stronger then bow shackles, however the bow shackle can be a more useful shape for getting loops in.
Brendan
Post #244975 19th Jun 2013 10:38pm
rossy
x-isle wrote:
Alloy looks a bit nicer when bare. Steel will/should be galvanised so not too shiny.
The brackets shouldn't be alloy, they should still be galvanised.
As for thickness, if going for an alloy plate with galvanised brackets, you should go for 10mm brackets and 8mm plate.
If you go for all galvanised, then you don't require the plate to be so thick.
After looking around for mine, I ended up going with the Paddocks PM716 as the price is great and the finish is actually brilliant. http://www.paddockspares.com/pm716-heavy-d...ender.html
The other thing to consider is are you going to actually use it or is it for show? If you are going to be smacking the life out of it every couple of days, then possibly the full galvanised one would be better.
In my opinion, if there is a chance that you will be using it, even occasionally, then I wouldn't go for any painted or powder coated one.
I've got the same one as x-isle. Looks great and excellent value for money. Thumbs Up
Post #245038 20th Jun 2013 8:57am
farmer giles
Sphere wrote:
I am thinking of removing mine and fitting the military style bar and possibly dan bars. Mainly as I am putting a multi mount on the front for the snowplough and winch and don't want to cut the guard but partly I find when I am stuck it acts a a plough when being recovered backwards and lifts the front wheels out of traction when going forward
i've got a nearly new military bar not yet fitted - if your steering guard is a mantec/land rover one i would happily swap (plus cash as yours is more expensive)?
Post #245052 20th Jun 2013 9:44am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Ditto - I have that one on both my vehicles, finish has stayed good for 6 years on the 90, no rust! Recommended Thumbs Up
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #245056 20th Jun 2013 9:48am
JSG
West Midlands 4x4 - looks the business, very solid and the bars can be replaced if you bend one, not that likely though as they are challenge tested.
 John
2011 Tdci 110 CSW XS
Post #245165 20th Jun 2013 6:31pm
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
I'm using a Paddock HD Galv steel plate, and really happy with it.
It's not that heavier than the good aluminum ones (18kg) and can take a beating, and I mean a good beating.
The recovery eyes are also handy, and besides being hot dipped galvanised I painted mine with zinc ritch black paint. Looks great and ends being extremelly rust resistant
Post #245168 20th Jun 2013 6:54pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I am afraid it's not a lr or Manteca one. It's a aftermarket alloy one that came with the vehicle. Pm if your still interested I haven't got round to removing it yet.
Post #245667 22nd Jun 2013 8:09pm
Page 2 of 2 <12
