![]() | Home > Technical > Death wobble and steering box play |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
Yes, the manual states that if you adjust the steering box (by loosening the locknut on top, then turning the middle allen screw) to do it with the steering in the straight ahead position.
If you adjust it with the steering to the left or to the right, then at straight ahead it will become very tight. |
| Arierep Member Since: 13 Apr 2013 Location: Portugal Posts: 258
True,
But am I supposed to end up with very little play at the center and a load of it at the sides? |
| wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581
It's probably not just play in the steering box. You probably have a little play in several places. Something rotating (wheels, brake discs etc) is setting off the wobble and the play in these other areas is amplifying the issue.
Perhaps look at the following. Wheel bearings. Kingpins. Panhard rod bushes/bolts. Steering ball joints drag/track rods and so on. |
I think that's the general way the steering boxes work... you set up the "center" position, and there is more slack at the sides, BUT if you set it up at the sides, then naturally the center will be too tight. |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
Are you sure you haven't just lost a balancing weight off one of the front wheels as the problem seems to have come on fairly suddenly as you stated in your original post.
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Like I said before, with the axle lifted I saw no play on any componet from the drop arm on
Could a missing rim weight be causing such a sudent and intense steering wobble? |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6053
Sounds like you have the wrong preload on the swivels.
Andy |
Jose - Yes. Unbalanced wheels can give you significant steering vibration. Simple to check and not uncommon, especially if you Offroad even a little.
Ok, I just went to the car and checked again.
With the axle on the floor, and the engine running (power steering on) there seems to be zero play at center. Every little move I make on the steering wheel is translated in wheel movement. A quick check revealed that a few weights are missing on the front left wheel. Might this be the problem? |
Swap front wheels to rear, easy test.
Andy |
Just found the cause of all the problems, a worn out panhard bushing.
I'll try to replace it ASAP. What kind of problems can arise from drive it like it is? Thanks for all the help |
Messy pants from fear of death from nasty shaking, and the fact it pulls one way on power other way off power.
Andy |
Note to the future:
In case of steering problems, always check with PS-off/axle-up and PS-on/axle-down. Different things are detected in different conditions it seems |
| Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335
Death wobble and the subsequent destruction of panhard rod bushes is usually a result of incorrect swivel preload(s).
