Home > Maintenance & Modifications > Installing a aux power socket in the rear
Page 2 of 11 <123 ... 91011>
ericvv
Post #234861 12th May 2013 1:11pm
Thumbs Up Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #234866 12th May 2013 1:21pm
ericvv wrote:
Saw this week that on a model year 2013 Puma 2.2 station wagon that there are two wires ending in a plug dangling out 10 cm or so from the right hand side chassis rail somewhere 20 cm or so before the rear crossmember. Saw it at a friends new Defender while we were at the dealer. When asked about what these cable are for, they just did not know. Could it be that after the purple and black live wires behind the right hand side rear speaker panel were abandoned on model year 2013, that those wires/plug dangling out of the chassis rail are the new live wires which could eventually be used for a rear work light or other? A rear work light remains an option, so the juice must be taken somewhere, yes? Any 2013 model year drivers able to shed light on this?
Eric
I'll check this out tomorrow...
Post #235009 12th May 2013 9:00pm
mobilecentre
The whole wire has not been deleted just the two way connector that goes "nowhere" has been removed from the loom the cable still continues from Fuse 2 under the seat through to the rear loom and terminates in the towing electrics connector in the rear wheel arch.
Post #240422 2nd Jun 2013 11:21am
mobilecentre
Instead of making the extension leads if you take a small screwdriver you can release the locking tab on the terminals within the white plug and remove them.
These are standard spade size so will fit straight onto the Sutars sockets such as http://www.mobilecentre.co.uk/index.php?ma...cts_id=699 and the Blue Sea twin USB http://www.mobilecentre.co.uk/index.php?ma...cts_id=653
The ones I have taken to pieces have the additional locking pin that locates in the small hole within the tab on the socket so they will not fall off unlike the standard crimps which are an interference fit and may shake loose. A piece of heat shrink over each terminal will insulate everything and save the need for extensions, crimps tools and terminals and be more secure Thumbs Up
Post #240424 2nd Jun 2013 11:27am
JWL
A little bit off topic but I had to put a new 12N socket on yesterday so the easyist way was to take off the loom from behind the rear fog light panel. On that loom(2002my 110) were 3 extra wires, green/red ending in a Lucar for reverse light, purple ending in? Had fallen off probably another Lucar to the fog light circuit and another purple wire ending in a female bullet that was a seperate live feed.
Post #240429 2nd Jun 2013 12:16pm
Kitoper
Switzerland
Hello Tim, I am really interested in doing what Eric has done, but I have a MY2013 2.2 110 and was wondering if you could give me some additional guidance here as to where these two wires can be found and if they are purple and black like before. I would be very grateful for any support you can give.
Thank you
Post #243457 14th Jun 2013 8:08am
mobilecentre
The purple and black wires ran along the loom to the tow bar socket with a T off for an aux power socket. This T was deleted on MY2012 so now the wires run to the tow bar socket so the only way you will be able to install the socket is by splicing into the OEM loom.
Post #243468 14th Jun 2013 8:58am
Kitoper
Switzerland
Thank you Tim - I will take a look this weekend and then follow-up.
I wish you a good weekend.
Post #243516 14th Jun 2013 12:35pm
JWL
If you have a tow socket loom like on mine, genuine LR supplied in 2002, then the spare power wire breaks out of the taped up loom in a plain purple wire with a bullet connector on the end not far from the white block connector. You may be lucky and it may still be made in this fashion. I accessed mine from underneath, behind the plastic splash guard covering the rear light panel.
HTH
Post #243537 14th Jun 2013 1:24pm
mobilecentre
Td5 uses the same tow bar connector on the loom as Puma but not all the pin locations are used. The purple wire being one of them which is why it is left loose. On the Puma the purple wire terminates in the tow bar connector.
Post #243564 14th Jun 2013 2:42pm
JWL
Must have had a deluxe version then Whistle
Post #243574 14th Jun 2013 3:06pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Thanks for the info, just ordered a few sockets to scatter about the vehicle.
One question though - those pesky trim clips/screws, before I get stuck in with my screwdriver or panel remover, how do these ones work, is it just a case of unscrewing the centre pin, removing it then popping the bit that's left with he panel popper? Or is there some other trick Confused
Thanks
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #247791 30th Jun 2013 4:23pm
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
just had a look on my MY13 and the connector or loom for the towing electrics don't exist behind the rear speaker.... 2013 Aintree Green 110 Station Wagon SX
Post #247826 30th Jun 2013 6:26pm
mobilecentre
The purple wire branch to the white plug was deleted in 2012 on the 2.2 so this mod is not applicable to MY2012 or later
The purple wire is still there just runs in the rear loom to the tow bar socket and terminates and the connector in the wheel arch.
Post #247827 30th Jun 2013 6:29pm
