![]() | Home > Technical > Differential |
Anyone know what the two threaded holes in the side of the diff are for or is it another case of "why is there a big hole in the rear chassis cross member"
![]() [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
I think that you'll find that those are fit a bracket to hold a harmonic damper on other models that use the same diff.
Edit - the P38 Range Rover has an harmonic damper fitted here on auto models. See very small ebay picture |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
^^^ as black wolf said, P38 hang over.
some manf. now use them as mounting holes for diff guards. depending on your year of build will depend whether or not you have those holes. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks - when you know what to look for, it's easier to find photos: ![]() Click image to enlarge |
