Home > In Car Electronics > How do you extract an Alpine head unit?
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi Guys,
I expect this is a very simple question when you know the answer, but I am reluctant to go poking around these fragile little things too much without an idea of what I am trying to achieve.
I want to extract my head unit to attach some new woofer cables, I have got the front panel of the radio off but now I'm not sure how to proceed to extract the unit itself.
Knowing how clever you lot are, I'm optimistic someone will know the answer and can oblige....?
Many thanks.
John.
Wink 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #241725 7th Jun 2013 3:58pm
You will need some Alpine radio removal keys. That OR remove the centre dash and you can remove it that way. The keys solution is the simplest providing they fit correctly however removing the centre dash would mean you could avoid buying any but is a pain everytime you want to whip the HU out. As I assume it's an Alpine unit fitted from factory LR could probably supply these. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #241728 7th Jun 2013 4:04pm
Natlas
Sounds simple enough Steve, LR don't do them but my local Halfords does so I'll be down there in the orning, they can take it out and then sell me whatever tool they used to do it!.
Thank you.
By the way, the Alpine woofer came today, it has so many leads with it I'm sure no extras are required.
Thumbs Up
Cheers,
John. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #241735 7th Jun 2013 4:33pm
That's good then. just make sure they don't touch anything except removing it. Or it will likely be mucked up. Rolling Eyes Whistle ____\We|Will|Win/___
Post #241738 7th Jun 2013 4:44pm
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
I find opening up the centre console is the easiest by miles. Loads of room to broddle about (I don't know how gynaecologists do what they do) then easy to seat it all back. No risk of scratching anything too.
C 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #241751 7th Jun 2013 4:56pm
Natlas
Hi Mrandmrsh,
Console extraction sounds very interesting as it will give me a chance to look around to see where the rain's getting in Confused Also recommended as worth investigation by the local radio installer who felt that my front plastic radio cover seemed to be wedged in rather tightly.
Are there any things to look out for - heater connections etc that migth prove awkward when reassembling?
Thanks,
John.
Thumbs Up 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #241968 8th Jun 2013 2:09pm
I know you were talking to the OP (And don't wish to cause any offence) But removing the centre dash you shouldn't have any trouble with at all. And not a lot you can do wrong. All I would mention is check there is no trapped cables between the centre dash and the rest of the dash when re-fitting & also check no cables and getting in the way of the lower controls as they are mechanical especially the heater and venting slider controls. CHeck that no wires are affecting these. If you need room to store any excess cable there I'd recommend the recess below these controls to the rear of the diff lock warning sticker there is no issues with getting in the way of anything there. Thumbs Up ____\We|Will|Win/___
Post #241969 8th Jun 2013 2:26pm
Natlas
HI Steve and Mrandmrsh,
Am I missiing something? I have undone the two large screws, one either side of the centre console but nothing wants to come out, it is stuck fast, is there something else I have to undo? or a particular direction to push/pull before anything moves?
I have put thin plastic levers down either side and tried to persuade it to move but it's not coming out!
Many thanks,
John, getting on with the wing tops now while hoping for a reply on this!
Confused 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #242199 9th Jun 2013 11:18am
mrandmrsh
A mix of pull from the bottom and get your fingernails in at the top just between the moulded centre dash and the black pen holder is roughly where u need to be. If stuck I can nip and do a pic but in the bath now lol
Post #242201 9th Jun 2013 11:29am
bob neville
To get the unit out you need these keys, it says Sony but they are the exact ones needed to remove the Alpine head unit Thumbs Up
http://www.caraudiodirect.co.uk/products/c...tAodvkIAEw
2013 Defender 90 CSW - sold
Post #242202 9th Jun 2013 11:35am
Natlas
Hi Mrandmrsh,
Thanks for your latest tip, using more force and starting at the bottom was indeed the way to go and it is now on its way out. Can't understand why you were typing to me last time from the bath! ? but glad you did anyway.
Now let's see what I find when I extract this thing....... Thumbs Up
Cheers,
John. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #242205 9th Jun 2013 12:00pm
Natlas
mrandmrsh,
Any idea where i should connect my 'power-on' wire too for the woofer?
Thanks, hopefully last question!
JOhn. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #242210 9th Jun 2013 12:34pm
John Baron wrote:
mrandmrsh,
JOhn.
To the Amp usually extremely near to the power and earth terminals on the Amp from the battery. Thumbs Up There will be three terminals on the Amp. Battery - + and remote + If you take a peak in my Gallery on here on my Amp you will see the remote turn on is in between the power and earth. Thumbs Up ____\We|Will|Win/___
Post #242211 9th Jun 2013 12:44pm
Natlas
It's the connection at the head unit I am after, I'll see if I can find a head unit wiring diagram.
Cheers,
John. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #242223 9th Jun 2013 2:02pm
If you don't have it to hand they are often available online to download instead. Kenwood's are at least so I'd imagine yours could be too even though Alpine.
Thumbs Up
They are usually about 6" max or less like a tail with a bare end usually with a tag on for insulation purposes. Thumbs Up ____\We|Will|Win/___
Post #242226 9th Jun 2013 2:25pm
