![]() | Home > Off Topic > Socket Adaptor. Where can I buy one? |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1139 ![]() ![]() |
Halfords? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
^^Already tried, and they don't do one
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
One of the biggest names and they don't do any.
![]() ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Splitpin Member Since: 07 May 2013 Location: Midlands Posts: 100 ![]() ![]() |
You need to go 1/2 to 3/8 then 3/8 to 1/4.
Tbh using a 1/2 wrench on a 1/4 socket is asking for something to get broken! |
Snap On USA or do it in stages
Hey sometimes I have to use a 1inch drive on a 17mm bolt
Other way around. I have a 22mm 1/2" socket, and need to use a 1/4" wrench on it ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Snap on definitely do one as I have one. Look out for your local rep driving about
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1861 ![]() ![]() ![]() |
Cheap 1/2" ratchet and cut the handle off short??
Keith |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Try macine mart.
http://www.machinemart.co.uk/shop/product/...et+adaptor Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
I don't have to look out for him, he comes and sees me twice a week! I'll have a word with him! ![]() If not, I may have to use a 3/8" instead of a 1/4", but that all depends if a 3/8" extension bar will fit in the gap that I need it to ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
If it gets desperate you could allways weld a 1/4" drive extension onto the 1/2" drive 22mm socket and by doing so tailor make the length of the extension to your needs.
^^Thanks for the suggestion JWL, if all else fails then that may well be the best way forward. I'm going to go and see if I can get a 3/8" bar to fit in the gap, and if not then on the plan B, seen as I can't find the adaptor I need
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17987 ![]() ![]() ![]() |
Why not use a 3/8 dr socket, and a 1/4f to 3/8m adaptor, both which are widely available?
