![]() | Home > Maintenance & Modifications > Old ground but any new thoughts? Checker plate options. |
They have and it is now fitted on the white 90. It looks absolutely beautiful. I have it from a reliable source that it will be I. The land rover world mag that comes out at the end of June. Bren will no doubt fill you in on the details at some point when he has a minute Barbara |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
If you plan standing on the wing tops then reinforcers are a good idea. |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
HI SGH, can you confirm you sell the Mammoth wing tops?
Thanks, John. 2.2 90 XS 88" Series One Old Norton ![]() Minerva |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3495 ![]() ![]() ![]() |
Is that only entreq then? 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
If you 'need' to stand on the wingtops one would surmise you've a roof rack. Why not consider the bonnet, you can definately stand on that no bother? Never a feint heart 'n' all that....It does involve drilling 28 holes though.
![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Yes ![]() |
Yes we can get Mammouth CP ![]() |
Hi SGH,
OK I'll call you monday to sort out some Mammoth CP wing tops. It will be for a 13 plate defender, RH aerial hole, 3mm thick plain Ally unless you can convince me there is some benefit in anodised silver? I will need the countersunk stainless screws and foamy bits to go between plate and wing. Do you do the rivnuts? preferably with a couple spare so I can set the tool up correctly. If not, no problem as I can source the rivnuts locally. Thanks, John. 2.2 90 XS 88" Series One Old Norton ![]() Minerva |
Unnecessary quote removed
PM sent |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3796 ![]() ![]() ![]() |
Wow..what a great looking vehicle. What sort of headlights are fitted? Cheers, Pickles. |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
W reg with a bump bonnet?
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
Private plate. Darren
That's mean and aggressive looking, nice.
Yes, rack and most weekends has 5 bikes on it. 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Thank you...
It's a 08 XS and yes it's obviously on a private plate... ![]() Headlights are JW Speaker, wingtops, sills etc. are OEM LR chequerplate and bonnet Mammouth. Regards MAL ![]() Treat every day as if it is your last....one day you will be right!! |
