Home > Puma (Tdci) > HELP no headlights.
Page 1 of 5 12345>
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
HELP no headlights.
2011 puma.
Driving back from Manchester late last night, cleared the 50mph zone and the lit section on the M62 and realised I had no headlights Sad
Still had 35 or so miles to go.
The high beam flasher worked but no dip or main beam otherwise.
Checked all the fuses this morning and all ok.
Lights are standard.
Any clues before I ring the dealer?
Amazed that nobody flashed me, the only light I had at the front was the near side sidelight.
Post #239717 30th May 2013 4:12pm
Kev stephenson
United Kingdom 2005 Defender 110 Td5 XS CSW Java Black
I had the same a few months ago and mine was the stalk that does the dip to main. There is a small metal contact that connects either dip or high that had melted, take off the column covers and have a look.
Mine is a TD5 but I believe they are the same set up 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
1996 130 300TDi chip truck for tree surgery business
Post #239718 30th May 2013 4:24pm
NoDo$h
That reminds me. Must wire in a relay to reduce the current on the switch. Here we go again, doing Land Rover's job for them Laughing
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #239721 30th May 2013 4:29pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Sounds silly but check the bulbs as well. I had an odd experience when both dip elements failed together Confused
found that out after I had checked all switches, relays, fuses etc. So it can pay to check the obvious first Embarassed BM52
Post #239722 30th May 2013 4:34pm
shaun.mobile
The main beams work from the stalk on flash (stalk pulled) but not on main beam (stalk pushed) so it can't be the bulbs.
Thanks for the reply though, you still enjoying 4 gears that manage themselves?
Post #239728 30th May 2013 4:59pm
bm52
shaun.mobile wrote:
..... you still enjoying 4 gears that manage themselves?
Oh Yes... Only today I went for a little wander along a green lane and then just had to go back the same way Rolling Eyes
I ma also commuting more so traffic jams are not an issue any more.
Cheers BM52
Post #239733 30th May 2013 5:05pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
See here on this thread. [url] http://www.defender2.net/forum/topic19350....elay[/url] Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #239737 30th May 2013 5:13pm
keith
Same happened to me few wks ago . Traced problem to the 3 pin headlight plug ( the one that plugs into the headlight ) the metal clip contacts inside the plastic housing had spread open , crumbled and shorted causing the plastic to melt and no lights . Very poor quality and cheep nasty part .
Post #239806 30th May 2013 10:17pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Sadly, same could be said for any number of parts in a Defender....
Post #239811 30th May 2013 10:27pm
shaun.mobile
UPDATE
Had land rover assist out.
Checked fuses, relays, connectors and the main light switch, all seemed to be ok.
Technician diagnosed fault in column switch, off to the dealers for repair.
I have given them a list of other issues to work through;
1. Leak on fuel tank when full.
2. rusty headlamp rings (dealer pointed out that they are a no cost option).
3. Rusty front bumper (apparently this is standard fit to all defenders).
4. Radio interference when aircon kicks in.
5. Rusty rear crossmember.
Now slumming it in a 2013 freelancer with all the toys.
Post #240031 31st May 2013 6:58pm
keith
shaun.mobile wrote:
UPDATE
oh how it all sounds so familiar. Welcome to the defender club.
Post #240039 31st May 2013 7:18pm
Eduardo
Too familiar...
I changed this switch 3 times Evil or Very Mad Eduardo
Post #240046 31st May 2013 7:37pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Hi guys,
just to confirm that all puma defender are fitted with headlight relays now?
they are the R122 relays on the diagram??
THanks
Martin
Post #300766 21st Jan 2014 2:08am
ericvv
Martin,
If that were the case, it would have been reported as breaking news all over the forum I think. Laughing
Wishful thinking, that would be too much inventive engineering at the end of the current Defender's lifespan.
Off Topic Draw a line to the here much hoped for supercharged V8 limited edition which some report will be offered as a last edition.... I am afraid if they never could correct the lack of a simple relay for the headlamps, that the chances that they will put engineers on a job to safely shoehorn such a V8 into the Defender engine bay with all the required upgrades to transmission and brakes, etc. as pretty slim/non-existent. Laughing
Afraid the headlamp relay remains just an after market job, but as you have seen reported in recent threads, there are options on the market, notably in Holland. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #300779 21st Jan 2014 7:53am
driver9
tuesdayfox wrote:
Hi guys,
THanks
Martin
Relay above OBD socket is for headlights according to the workshop manual.
Post #300784 21st Jan 2014 8:19am
Page 1 of 5 12345>
