Home > Puma (Tdci) > 2013 - Alarm
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
2013 - Alarm
Hi all
Does anybody know if the factory-fit alarm on a 2013 XS is Thatcham rated, and if so to what category?
Cheers My Disco 'best bits'
Defender 110 XS CSW 2013
Post #239533 29th May 2013 7:53pm
bob neville
Cat 2 Thumbs Up
Page 4 on the link below.
http://www.thatcham.org/security/pdfs/cate...arCAT2.pdf
2013 Defender 90 CSW - sold
Post #239558 29th May 2013 9:09pm
DiscoStu
Cheers. Censored , needed a Cat 1 for the insurance My Disco 'best bits'
Post #239578 29th May 2013 9:59pm
Porny
Site Sponsor
Standard Alarm can be upgraded... means you keep the standard LR fob (or I can do you an all in one key).
http://www.mobilecentre.co.uk/index.php?ma...cts_id=637
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #239599 29th May 2013 10:35pm
DiscoStu
Cool That's great - was going to be in contact about cruise control soon anyway Thumbs Up My Disco 'best bits'
Post #239618 30th May 2013 5:05am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
This is strange as the definition of Cat1 is alarm and immobiliser whereas CAT 2 is immobiliser only. I thought that Puma's had immobilisers AND alarms so would qualify as CAT1, at least those with the battery back-up. Wonder what it is about the alarm that doesn't qualify it for CAT 1 status.
From Thatcham website...
Category 1
Passenger Cars, LCV, HGV, Plant, Motorcycles
ELECTRONIC ALARM AND IMMOBILISER
Alarm
Perimeter detection
Ignition detection
Passenger compartment movement detection
Inclination detection (Motorcycle only)
Audible warning with battery back-up power supply
Immobiliser
Passively set
Isolates a minimum of two operating circuits or systems, or a minimum of one operationally relevant vehicle control unit with coded intervention
Edit: okay think that the Defender alarm does not have a proximity sensor and thus fails the "perimeter detection" requirement?
Post #239736 30th May 2013 5:11pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
I reckon Perimeter protection are the door/bonnet contacts, so it would be okay on that basis.
I don't know enough about the immobiliser in terms of circuit/ecu isolation so not sure if it falls down there but I can't see Thatcham approving an alarm system where traditionally (assuming MY13 no different) , they locate the audible element in an area that is not even partially protected by the alarm zones Jon - 110 td5 [sold]. Currently Defenderless.
Post #239747 30th May 2013 5:53pm
Probably the fact that a badger with a blunted spoon can bypass it and steal the doors/bonnet/whole thing without anyone hearing! Rolling with laughter Rolling with laughter
Post #239768 30th May 2013 7:42pm
kmac
party monkey - the immobiliser is fine, that's why its CAT 2 - as far as Thatcham are concerned all it has is an immobiliser. If it had a decent alarm as well it would qualify as CAT 1.
Just wondering if alarm was classified on the basis that the battery back up was not standard issue untll MY 11 onwards.
Diesel jim - are the battery back up alarms not "badger proof"?
Post #239800 30th May 2013 10:02pm
LR90XS2011
How would you know if you have Battery Back Up DEFENDER 90 TDCI XS,
Post #239801 30th May 2013 10:08pm
kmac
Disconnect the battery and see if the alarm goes off (make sure you have your radio code)
I do believe from MY 12 onwards (2.2 TDCi) they were standard issue
Post #239807 30th May 2013 10:18pm
mobilecentre
Battery back up was a cost option but standard IIRC on XS spec not sure about MY2013
Even with battery back up LR would still have to submit it to Thatcham for testing and approval before the insurance company recognised it.
Post #240406 2nd Jun 2013 10:02am
kmac
I have an 59 plate XS - battery back-up was a cost option, not standard
Post #240426 2nd Jun 2013 11:54am
mobilecentre
Bow down I stand corrected thanks for the update Thumbs Up
Post #240427 2nd Jun 2013 11:57am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
But you can add a 3rd party rechargeable battery sounder to the car electrics that sounds off if the battery is disconnected. In fact you could add more than one in different positions. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #240470 2nd Jun 2013 4:36pm
