![]() | Home > Maintenance & Modifications > Chevy Ls1 specialist down south? |
| stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1034
Haven't had any dealings with the. But pass them every day at work , maybe worth a call
Www.newforestclassicamerican.com |
| davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888
I've not found anyone in particular in the UK however I've used Claremont Corvette for some service items and spares...
http://claremont.corvette.co.uk They may be able to point you in the right direction at least. Most of the spares for mine I've ended up buying in from the US, usually from http://www.jegs.com but I have got UK sources and part numbers for a few bits and pieces. So far I've done all the work on mine myself, it's a pretty easy engine to work on, on the whole most of it is pretty well thought out and being a modern design it uses reusable gaskets. Oil filters can be sourced in the UK if you ask for a K&N HP-1007, things may have improved in the last 5 years but when I first fitted mine nobody listed an oil filter for the LS1 or could supply the FRAM filter mine came with. http://www.yorkshireoffroadclub.net/ |
| All times are GMT |
