Home > Maintenance & Modifications > Chevy Ls1 specialist down south?
nickh90
England 1989 Defender 90 V8 Petrol SW Auto Java Black
Hi all,
Anyone know any good people with knowledge/experience with the Chevy LS1 engine? want to make a few changes and run some tests on mine to see how it is running and or could be improved upon.. I have a marine ECU which is very basic for both diagnostics and tuning capability but good if wet Smile.
Thanks
Nick
Post #239430 29th May 2013 7:19am
stanley
Haven't had any dealings with the. But pass them every day at work , maybe worth a call
Www.newforestclassicamerican.com
Post #239433 29th May 2013 8:06am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
I've not found anyone in particular in the UK however I've used Claremont Corvette for some service items and spares...
http://claremont.corvette.co.uk
They may be able to point you in the right direction at least.
Most of the spares for mine I've ended up buying in from the US, usually from http://www.jegs.com but I have got UK sources and part numbers for a few bits and pieces. So far I've done all the work on mine myself, it's a pretty easy engine to work on, on the whole most of it is pretty well thought out and being a modern design it uses reusable gaskets.
Oil filters can be sourced in the UK if you ask for a K&N HP-1007, things may have improved in the last 5 years but when I first fitted mine nobody listed an oil filter for the LS1 or could supply the FRAM filter mine came with. http://www.yorkshireoffroadclub.net/
Post #239434 29th May 2013 8:27am
