Home > Puma (Tdci) > Cruise Control
Page 2 of 5 <12345>
munsterlandy
Ireland 2008 Defender 130 Puma 2.4 HCPU Santorini Black
sonic3d
sonic3d
any update on cruise ? Whistle
Thumbs Up
Post #23874 8th Feb 2010 8:21pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Sorry chaps did not know about this thread till now Embarassed Yes we fitted cruise fitted to the 110 and 90 and all i can say is its fantastic Thumbs Up We are looking into buying some kits if there is enough interest Thumbs Up
Post #23875 8th Feb 2010 8:28pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Sonic can you post up more information on these kits. I think I'd be after two if they are easy to install. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #23883 8th Feb 2010 9:38pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Interest registered! is it a simple to use system? how is it controlled? and does it require any wire hacking / modification? Very Happy Very Happy Very Happy 110 Tdci Double Cab
Post #23884 8th Feb 2010 9:41pm
munsterlandy
interested
i don't think you'll have much trouble drumming up interest Mr. Green
Thumbs Up
Post #23887 8th Feb 2010 10:05pm
Sonic3d
It very simple to install and calibrate, it is controlled by a small control pad that is best mounted on the flat surface to the side of the radio/heater controls.
It needs an analogue can bus signal for the speed sensor - taken from the rear of the dash
A wire to the clutch switch on the pedal box under the bonnet
A wire to the brake switch on the pedal
Power and earth
Post #23891 8th Feb 2010 11:05pm
munsterlandy
yes please
looking forward to pm Whistle Whistle Whistle
Thumbs Up
Post #23892 8th Feb 2010 11:09pm
K9F
Interest Registration!
Interested dependant on costings! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #23893 8th Feb 2010 11:20pm
dgardel
Italy
me too Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #23897 9th Feb 2010 12:55am
BBSJK
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I'd be interested, depending on the pennies. It's the only thing I miss from the 'normal' car when I'm in the Landy. No the other left . . .
Post #23952 9th Feb 2010 8:48pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
I am also interested Sonic! Thumbs Up
Apparently the firm that supplies Terrafirma's cruise control has gone bust!
Post #23977 10th Feb 2010 8:48am
Naks
Read on an Aussie LR forum that this Waeco unit is compatible with the Freelander 2, which may mean it is compatible with the Puma as well:
http://www.waeco.com/en/3512_1340.php
http://www.waeco.com/en/4374_1340.php?artOrigID=35503&sprID=2
Post #23979 10th Feb 2010 10:47am
kljw
so, this may be a dumb question, but can it be fitted to a puma based 90? and does it plug into the port under steering wheel?
but most of all. how much and when can i get one? Cheers
keith
puer claudius
Post #24019 10th Feb 2010 9:42pm
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
This unit is compatible with Ford Transit (2.4TDCi Engine), so I assumed it would be applicable to the Defender.
I tried to get an answer out of WAECO on this, and was met with silence.
Perhaps they don't ship to AUS, and that's why they ignored me.
Post #24020 10th Feb 2010 10:08pm
Naks
draymond wrote:
This unit is compatible with Ford Transit (2.4TDCi Engine), so I assumed it would be applicable to the Defender. I tried to get an answer out of WAECO on this, and was met with silence.
If it is compatible with the Ford Transit, then it "must" be compatible with the Puma. After all, both use the Ford CANBus, but do they use the same ECU?
Post #24041 11th Feb 2010 6:55am
Page 2 of 5 <12345>
