Home > Maintenance & Modifications > Side hinged tailgate.
SGH
Thinking of converting the fold down tailgate on my Series 3 to side opening any tips on doing this.
Simon
Post #238791 26th May 2013 8:50pm
Litch
This is mine, did it nearly 14-years ago and still works perfectly. You can buy the correct item from LR but mine was a DIY set-up.
Normal tailgate stripped of all fittings. Pair of hinges mounted to O/S and a pair of brackets on the N/S matched to "up & over catches" mounted on the tub. Swingaway spare wheel carrier takes all the weight of the wheel. Galvanising of the steel liner was done a couple of years ago.
Beware. The tailgate is not reinforced for the hinges & brackets so if you aren't careful you could end up crushing the double skin. I used locknuts to ensure this didn't happen and as I said, been on nearly 14-yeards now without any problems.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ONE LIFE, GET IT!
Post #238824 26th May 2013 9:49pm
Retroanaconda
Post #238840 26th May 2013 10:46pm
SGH
Thank you for the info Thumbs Up
Post #238899 27th May 2013 9:42am
Re: Side hinged tailgate.
Simon
No don't do it Big Cry
Sitting on the tailgate is the most quintessential of Land Rover experiences. Listen to the rumblings of the Disco and RR boys when it was taken away/given back.
Having said that I do like the side opening tailgates. I'm sure I've seen some very clever hinge arrangement somewhere else that would allow both if it could be made to fit. Just can't think on what at the moment. Embarassed
Post #238950 27th May 2013 2:04pm
SGH
What wheel carrier do you have on this ?
Post #241123 5th Jun 2013 7:49am
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
There's a clever hinge arrangement on the back of Ifor Williams horse trailers, the double doors can be opened as a barn door or as a ramp for loading horses. Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
www.lothian4x4response.org
Td5 90
Thread in 'My Defender' Forum
Post #241145 5th Jun 2013 9:55am
That sounds interesting...off to look at next.
Post #241147 5th Jun 2013 10:04am
Side hinged tailgates let you walk into the towing hitch much more easily!
I am sure you don't need to be told how I found that out.
Post #241148 5th Jun 2013 10:10am
K9F
Just an idea but you could always get some spacers made up the same depth as the double skin, fit stainless washers and then tighten away to your heart's content without the fear of crushing anything. I had extras made for my rear crossmember when I fitted my swingaway to prevent just that.
Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #241149 5th Jun 2013 10:18am
