![]() | Home > Maintenance & Modifications > heated mirrors |
| Juddy Member Since: 09 May 2013 Location: Queensland Posts: 63
Are the 24 volt mirrors that are for sale on ebay etc, suited to a 12v land rover, ie can they be used with some modification.
And how are they fitted. 2010 Defender 130 HCPU 1991 110 RFSV PERENTIE www.landybitz.com.au |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Why not buy a 12V kit?
http://www.ebay.co.uk/bhp/land-rover-defen...5573.m2388 Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Well good thought, but I have 24v Wolf mirrors going spare. 2010 Defender 130 HCPU
Good point Jim
Thank you mate... 2010 Defender 130 HCPU 1991 110 RFSV PERENTIE www.landybitz.com.au |
May be you can modify the heating element, i.e. like splitting the element in 2 parts (make a isolated part in the middle) and then supply the feed in pararallel. This way you have 12 V over the half of an element, which would have the same effect as 24 V over one whole element. Cheers, Vincent
| CarlW Member Since: 21 Sep 2010 Location: Lanarkshire Posts: 53
Half Volts will result in 1/4 of the power not 1/2 the power - might still work but will be far less effective
Carl MY11 110 XS Station Wagon in Stornoway |
This way you put the same volts across each half element - which is effective the same as putting double volts across one whole element. ... Or do I miss something? 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
No if you can split the element into two equal sectiona and apply 12v across each half you;ll be back to full power
Thats exactly what I said 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
