Home > Maintenance & Modifications > heated mirrors
Juddy
Australia 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
heated mirrors
Are the 24 volt mirrors that are for sale on ebay etc, suited to a 12v land rover, ie can they be used with some modification.
And how are they fitted. 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE
www.landybitz.com.au
Post #238499 25th May 2013 10:04am
VeeTee
Netherlands
Why not buy a 12V kit?
http://www.ebay.co.uk/bhp/land-rover-defen...5573.m2388 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #238507 25th May 2013 10:43am
Juddy
Well good thought, but I have 24v Wolf mirrors going spare. 2010 Defender 130 HCPU
Post #238512 25th May 2013 10:53am
The heated bit is usually only a stick on element behind the glass, so you could remove the glass, take the 24v element out and fit 12v ones?
Although.... i suppose if you just stuck 12v through a 24v element, it would just only heat up half as hot as it should. might still demist the glass, just twice as slow.
Post #238515 25th May 2013 10:55am
Juddy
Good point Jim
Thank you mate... 2010 Defender 130 HCPU
Post #238516 25th May 2013 10:56am
VeeTee
Netherlands
May be you can modify the heating element, i.e. like splitting the element in 2 parts (make a isolated part in the middle) and then supply the feed in pararallel. This way you have 12 V over the half of an element, which would have the same effect as 24 V over one whole element. Cheers, Vincent
MySite
Post #238521 25th May 2013 11:14am
CarlW
Scotland 2011 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Half Volts will result in 1/4 of the power not 1/2 the power - might still work but will be far less effective
Carl MY11 110 XS Station Wagon in Stornoway
Post #238610 25th May 2013 10:41pm
VeeTee
Netherlands
Carl
Question
This way you put the same volts across each half element - which is effective the same as putting double volts across one whole element.
... Or do I miss something? Shocked Cheers, Vincent
MySite
Post #238625 26th May 2013 12:01am
CarlW
No if you can split the element into two equal sectiona and apply 12v across each half you;ll be back to full power
Post #238804 26th May 2013 9:11pm
VeeTee
Netherlands
Carl
Thats exactly what I said Question Rolling Eyes Evil or Very Mad Cheers, Vincent
MySite
Post #238807 26th May 2013 9:17pm
