Home > Maintenance & Modifications > Hannibal ladder lower step question
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
I want to ask if anybody has installed the hannibal 2 piece ladder? Maybe i am really dump but I was hoping there was no drilling, the holes don't exactly align very well and the crossmember only had 1 hole, am I supposed to drill? Maybe I am missing something, the instructions said bolt on no drilling
Post #237640 22nd May 2013 4:27am
You will need to drill two holes for the lower pair of holes but when I had one fitted I only used the top pair of fixings and it was fine Thumbs Up
Post #237644 22nd May 2013 6:16am
jst
a patriot one only uses the top fixings and that seems to work Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #237654 22nd May 2013 7:12am
ronwong
Ok, if the top is strong enough I will just use those. Cool!
Post #237656 22nd May 2013 7:17am
Cracka
2012 Defender 90 Puma 2.2 HT Fuji White
G'day Lads,
I have just fitted a Hannibal rack and ladder to my 90 as well, finished the ladder yesterday.
From what I gather (included instructions from Hannibal) you only use the top 2 bolts and attach the step to where the body bolts to the crossmember as in your piccy.
The bottom 2 holes in the step are for a spacer, it should have been with the step, it is just a piece of ally plate with countersunk allen key head bolts to fix to those bottom 2 holes of the step. It is meant to take up the difference between the body and the crossmember, as the crossmember sits back a little from the body.
I didn't actually use mine as I can just make the step onto the rear fold down step with my right foot and then my left directly to the bottom rung of the ladder.
Does every body get some wind noise with their Hannibal rack, mine kicks in about 80 kph.
Mick
Post #237676 22nd May 2013 8:31am
ronwong
I understand now. The bottom part actually just rest against the crossmember and when you step, it gives a slight counter force against your body weight. The spacer is to maker
Sure there is no gap so that it can add support. My crossmember is flushed to the bodywork, so I don't need it. Those 2 torx are hell hard to take out...
Mine is the full 2.8 rack for 110 and yes, wind noise comes in about 80-90km, unfortunately.
Post #237707 22nd May 2013 10:24am
Cracka
That's it mate. That's good you don't need the spacer then, the instructions in mine did say only if required.
Yes a bit unfortunate about the wind noise. It was unexpected as when I was deciding on what rack, I read sooooo many threads saying the wind cheater was noisy and the hannibal was great Sad oh well can't do much about it now. I'll have to pull the headlining and soundproof the roof and see if that helps.
Mick
Post #237717 22nd May 2013 11:09am
ronwong
I just installed the top part of the ladder, can i check, the clearance for the right side of the ladder vs the door is very tight? Ie, if my left hand is grasping the right bar of the ladder, i will slam into my fingers when i close the rear door? Also my rear door seems very tight now, probably some alignment issue, when i tighted the ladder nuts?
Post #237789 22nd May 2013 5:09pm
Cracka
Yes, the ladder is close to the door, just get in a habit of holding a step and not the vertical rail of the ladder when you close the door. I have about 4mm from the edge of the bracket that bolts to the body and the edge of the door opening.
I didn't have any issues with alignment. I put my ladder in position, tightened the gutter bracket and then marked the 2 holes to go through the body, removed ladder, drilled holes, replaced all and then tightened up, no issues here.
Post #237894 22nd May 2013 10:41pm
VeeTee
Netherlands
Re: Hannibal ladder lower step question
ronwong wrote:
How are these 2 bolts fastened? Are there captive nuts on the other side, a "nut plate", or just loose nuts - then are they easy to reach? Or is the crossmember tab threaded? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #238043 23rd May 2013 4:37pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
VeeTee wrote:
The cross member is threaded.
When I mounted the ladder to the body where the holes line up to the capping/where you drill through I used 2 cheap tap washers (ie rubber washers that you put in the taps on your sink) to seal the bolt holes from water and to provide a bit of spacing between the ladder and capping. I also used an old inner tube cut to protect the gutter from the ladder.
For mine I used the aluminium spacer on the step as discussed above. By the way if anyone plans to mount their 48" Hilift on the back crossmember - the step just misses the high-lift when it is mounted
Post #238102 23rd May 2013 7:41pm
VeeTee
Netherlands
Thanks. I guess this is for a Puma? Could one think this is the same for a 1996 300 TDi ? Cheers, Vincent
MySite
Post #238154 23rd May 2013 9:54pm
ronwong
I put my hand in the inside and felt a nut there. I have yet to takeout the torx, its to tight. If you say the cross member is threaded, then probably that nut is welded into the cross member.
Post #240973 4th Jun 2013 3:37pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
If you look either side of the bolts on your 300tdi you should see some rivet heads that hold a plate with the two captive nuts on it. There is no extra lip on the earlier chassis crossmember.
This is from distant memory. Someone will correct me if I am wrong!
Post #240989 4th Jun 2013 5:06pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
The nut plate riveted on is only for the centre bolts, the outside crossmember bolts unfortunately have nuts on the back! Good luck with those, they get very seized. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #241002 4th Jun 2013 5:52pm
