![]() | Home > Maintenance & Modifications > Rear Crossmember Replacement |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
Looks very good! Did they remove the rear floor to get full access or had you already done that?
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
He did the rear floor, I was suppose to have removed it and the tow bar before I got there.
fantastic job Yobbie, time to get some dinitrol on it now
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6215 ![]() ![]() ![]() |
That's some nice neat welding there.
Who was the waxoiler? |
That's a very neat job
![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Don't you mean who didn't waxoil it? Can't mention his name or company as last time he got a bit upset on here, but he's suppose to be a Land Rover specialist and thinks that the corrosion could be 'plated'. The two waxoiling treatments only cost £950 so you shouldn't expect too much I suppose |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3501 ![]() ![]() ![]() |
That welding is lush. Far better than the factory finish!
I thought he had stopped doing stuff on landies but its good to hear he is alive and well. Does he do a full range of rear x members or just TD5's? 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
I spoke to the guy a while ago , he can do whatever you wish i was thinking along the lines of the north offroad winch crossmember
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Will you need H/D rear springs now ?
![]() Steve |
pressbrake Member Since: 06 Oct 2012 Location: essex Posts: 31 ![]() ![]() ![]() |
I must have been evil in a former life, so yes Im still making landrover stuff ![]() |
I now know where I am getting my TD5's rear crossmember replaced when it needs doing later this year, that looks excellent
![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
TD5_dan Member Since: 24 Feb 2012 Location: Essex Posts: 449 ![]() ![]() |
Clive, its Dan must pop up and see you hear your after a Series ![]() 1970 Series 2A Station Wagon 1970 Series 2A hard top 1960 Series 2 1972 Series 3 |
Unnecessary quote removed
thanks dan think if found myself a nice old 2b forward control to use as a shop truck to drag in rusty old coilers for work ![]() |
The pictures don't do it justice, the welding isn't just better than factory, it's better than almost all of the welding I have seen. (and I see welding nearly every day). Bob you won't regret it, just get there sooner than later so there's good metal to weld to on the chassis and it doesn't need cutting back further. ![]() |
