Home > Maintenance & Modifications > Rear Crossmember Replacement
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Decided my 1999 TD5 crossmember needed repacing after removing the seatbelt support bar on the back this is what was left!
the compression tubes fell out & the jacking points wern't up to much glad I'd never had to use them. The othe side looks better but was splitting apart & I hadn't knocked the rust off.
This had been 'Professionally Waxoiled' when it was 18months old & then taken back to the same guy 2 1/2 years ago no sign of the waxoil here
and here. He offers a 5year guarantee!!!
the strengtheners under the floor had none (a bad corrosion point on my series)
as the top of the chassis at the back
so after some research I decided on using Black Sheep Off Road for one of there HD crossmembers
they are produced out of 6mm material and don't need the water trap box section will out last the rest of the chassis
The guys work is amazing (I work for a welding & fabricating co.). Lot of time taken painstakingly custom making every part to fit perfect nothing too much trouble & even cut the floor strentheners to leave the hole required to remove the fuel pump!
Post #237042 19th May 2013 10:17pm
JeremyJ
Looks very good! Did they remove the rear floor to get full access or had you already done that?
Post #237065 20th May 2013 5:20am
yobbie
He did the rear floor, I was suppose to have removed it and the tow bar before I got there. Embarassed
Post #237072 20th May 2013 6:47am
fantastic job Yobbie, time to get some dinitrol on it now Whistle
Post #237075 20th May 2013 7:26am
That's some nice neat welding there.
Who was the waxoiler?
Post #237077 20th May 2013 7:30am
GUM97
That's a very neat job Very Happy Thumbs Up An engine to TDi for!
Post #237192 20th May 2013 4:52pm
yobbie
Don't you mean who didn't waxoil it? Can't mention his name or company as last time he got a bit upset on here, but he's suppose to be a Land Rover specialist and thinks that the corrosion could be 'plated'. The two waxoiling treatments only cost £950 so you shouldn't expect too much I suppose
Post #237194 20th May 2013 4:53pm
familymad
That welding is lush. Far better than the factory finish!
I thought he had stopped doing stuff on landies but its good to hear he is alive and well. Does he do a full range of rear x members or just TD5's? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #237215 20th May 2013 5:36pm
ibexman
I spoke to the guy a while ago , he can do whatever you wish i was thinking along the lines of the north offroad winch crossmember Thumbs Up
Post #237229 20th May 2013 6:25pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Will you need H/D rear springs now ? Whistle 2005 Td5 90 XS
Steve
Post #237251 20th May 2013 7:26pm
pressbrake
United Kingdom 1990 Defender 110 Other SW Fuji White
I must have been evil in a former life, so yes Im still making landrover stuff Wink
Post #237305 20th May 2013 9:18pm
bob neville
I now know where I am getting my TD5's rear crossmember replaced when it needs doing later this year, that looks excellent Thumbs Up
2013 Defender 90 CSW - sold
Post #237307 20th May 2013 9:24pm
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Clive, its Dan must pop up and see you hear your after a Series Thumbs Up Looks another top job mate, glad people are seeing what a fantastic job you do on these cross members. 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #237310 20th May 2013 9:31pm
pressbrake
Unnecessary quote removed
thanks dan think if found myself a nice old 2b forward control to use as a shop truck to drag in rusty old coilers for work Whistle
Post #237324 20th May 2013 10:11pm
yobbie
Bob
The pictures don't do it justice, the welding isn't just better than factory, it's better than almost all of the welding I have seen. (and I see welding nearly every day). Bob you won't regret it, just get there sooner than later so there's good metal to weld to on the chassis and it doesn't need cutting back further. Thumbs Up
Post #237368 21st May 2013 7:03am
