![]() | Home > Maintenance & Modifications > Defender air con 'sticky out' grill |
Cutting edge innovation, Defender style
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
You cant stop progress!!! |
OH well more rust
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Liam,
Your Defender does not have factory fitted air con if it does not have the extended front end. More likely, it was dealer fitted (probably a late customer request). All Defenders come with the extended front end when built at the factory (and I think for certain regulations it always has the extended nose). Being a proper sad geek... [URL=] ![]() Click image to enlarge[/URL] If you zoom in on your picture of the front end, your Defender has the two diagonal bars for the slam panel - a proper factory spec air con does not have this set up. Circled in red. The genuine setup has different mounting frame as below. [URL=] ![]() Click image to enlarge[/URL] However, dealer fit air con (made by the same people) uses a different condenser and a slightly different mounting. It also fits without modifying the front end. I'm also intregiued how your intercooler and radiator are packaged... It should be from the front of the car - condensor, intercooler, coolant radiator (and engine). But in the pic it looks like your intercooler might be at the front. If you PM me your chassis number I can look at the build spec for you. Going back to the parts required... ASJ710060 is the surround Ł185 + vat retail 2x NJ108062 2x AB614065L 2x WA108056 2x WL108007L 2x MTC6332 2x AK612016 2x WA106045L 2x WL106005L 8x DZM100080 The upper fixing stay the same - but you need all of the above for the lower mounts to do it propely... I happen to have an as new air con front end for sale ![]() Ian Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
If Liam doesn't want it for any reason i'm also after one ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6691 ![]() ![]() ![]() |
But isn't Liam's an XS (his icon says it is) so would have factory aircon
They don't offer an XS hardtop...
Also, with my Land Rover spotter cap on... Which is very similar to a train spotters one, but without the manditory Peter Storm waterproof, cheese sandwiches and thermos flask. In his gallery it shows it with orange lens front indicators and black grills... An XS has clear lens and grey front plastics... Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
I've been lead astray by the profile icon
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2671 ![]() ![]() |
sorry about the icon id never noticed, and porny i will take the front end if you have one, you can pm me about it when you get a chance
the car from new to nowish is here for martin... http://www.defender2.net/forum/topic15909.html this is how the car looks next to my mates with a sticky out grill... ![]() Click image to enlarge |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
just to slightly hijack this thread - can my aircon grille be made flush but still keep the aircon?
prefer the flush look myself |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
I must say it looks far better with flush grille might even look into converting mine back to flush version.
im preferring the sticky out, with the foam a bar ontop too, there is a big gap between the a bar and the grill as the a bar is for an air con defender... i bought it when i first got the car unaware that mine was different as it came with air con... hopefully i can purchase porny's grill and when i go for some software tweaking it will be fitted.
josh_a_miller Member Since: 08 Oct 2012 Location: Bath, Zomerset! Posts: 101 ![]() ![]() ![]() |
What was the verdict then bud? Were you able to fit the later style “sticky out” grill?
Id like to put the later style on my 1988 if it’s doable Cheers ![]() Chancer |
