Home > Maintenance & Modifications > Defender air con 'sticky out' grill
Page 2 of 3 <123>
Cutting edge innovation, Defender style Rolling with laughter Darren
Post #236091 16th May 2013 4:27pm
JeremyJ
You cant stop progress!!!
Post #236093 16th May 2013 4:32pm
familymad
I think someone on here sits with a defender in front of his desk??? Noticing an extra screw Bow down 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #236094 16th May 2013 4:34pm
JeremyJ
Embarassed Laughing
Post #236095 16th May 2013 4:36pm
OH well more rust Whistle
Post #236105 16th May 2013 5:16pm
Porny
Site Sponsor
Liam,
Your Defender does not have factory fitted air con if it does not have the extended front end. More likely, it was dealer fitted (probably a late customer request). All Defenders come with the extended front end when built at the factory (and I think for certain regulations it always has the extended nose).
Being a proper sad geek...
If you zoom in on your picture of the front end, your Defender has the two diagonal bars for the slam panel - a proper factory spec air con does not have this set up. Circled in red.
The genuine setup has different mounting frame as below.
However, dealer fit air con (made by the same people) uses a different condenser and a slightly different mounting. It also fits without modifying the front end.
I'm also intregiued how your intercooler and radiator are packaged...
It should be from the front of the car - condensor, intercooler, coolant radiator (and engine). But in the pic it looks like your intercooler might be at the front.
If you PM me your chassis number I can look at the build spec for you.
Going back to the parts required...
ASJ710060 is the surround Ł185 + vat retail
2x NJ108062
2x AB614065L
2x WA108056
2x WL108007L
2x MTC6332
2x AK612016
2x WA106045L
2x WL106005L
8x DZM100080
The upper fixing stay the same - but you need all of the above for the lower mounts to do it propely...
I happen to have an as new air con front end for sale Wink
Ian
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #236137 16th May 2013 8:42pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
If Liam doesn't want it for any reason i'm also after one Thumbs Up
Post #236139 16th May 2013 8:46pm
Martin
Site Admin
But isn't Liam's an XS (his icon says it is) so would have factory aircon Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #236189 16th May 2013 11:05pm
Porny
Site Sponsor
They don't offer an XS hardtop...
Also, with my Land Rover spotter cap on... Which is very similar to a train spotters one, but without the manditory Peter Storm waterproof, cheese sandwiches and thermos flask.
In his gallery it shows it with orange lens front indicators and black grills... An XS has clear lens and grey front plastics...
Ian IRB
Post #236190 16th May 2013 11:11pm
Martin
Site Admin
I've been lead astray by the profile icon Sad Embarassed  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #236197 16th May 2013 11:45pm
Likeomg
sorry about the icon id never noticed, and porny i will take the front end if you have one, you can pm me about it when you get a chance
the car from new to nowish is here for martin... http://www.defender2.net/forum/topic15909.html
this is how the car looks next to my mates with a sticky out grill...
Post #236203 17th May 2013 12:53am
farmer giles
just to slightly hijack this thread - can my aircon grille be made flush but still keep the aircon?
prefer the flush look myself
Post #236241 17th May 2013 8:48am
SGH
I must say it looks far better with flush grille might even look into converting mine back to flush version.
Post #236262 17th May 2013 9:52am
Likeomg
im preferring the sticky out, with the foam a bar ontop too, there is a big gap between the a bar and the grill as the a bar is for an air con defender... i bought it when i first got the car unaware that mine was different as it came with air con... hopefully i can purchase porny's grill and when i go for some software tweaking it will be fitted.
Post #236295 17th May 2013 12:09pm
josh_a_miller
United Kingdom 1988 Defender 110 300 Tdi CSW Aintree Green
What was the verdict then bud? Were you able to fit the later style “sticky out” grill?
Id like to put the later style on my 1988 if it’s doable
Cheers Thumbs Up 1988 Defender 110 County 300tdi
Chancer
Post #853031 30th Aug 2020 7:32am
Page 2 of 3 <123>
