Home > Technical > Wiring diagram challenge
Tiger
Anybody solve this one (with relays and fuses)
1 12v Power outlet
2 x Batteries
1 on off on rocker switch
I want to be able to switch the outlet between the batteries Question (no common earth)
Pos 1 Switch (on) = Outlet connected to Bat 1
Pos 2 Switch (off) = Outlet not connected
Pos 3 Switch (on) = Outlet connected to Bat 2
Post #235184 13th May 2013 4:26pm
K9F
DPDT (Double Pole Double Throw) relay. Position 1 to one coil, position 3 to other job jobbed. Available from RS components. Depends on what you are supplying and expected current draw etc. Fuse both the relay coils and the relay feeds as well as the 12 volt power outlet. Can't give ratings as information above is too scant.
Relays below in link are up to 10 amps, any more current draw and you'll have to go heavier duty.
http://uk.rs-online.com/web/c/?searchTerm=...ss&r=t If you go through life with your head in the sand....all people will see is an ar5e!!
Post #235186 13th May 2013 4:41pm
I was going to mention something about a Relay but thought I'd better keep quiet and recommend K9F in case I give some wrong info. Whistle
Mr. Green ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #235187 13th May 2013 4:43pm
ibexman
Wheres PAUL Mc
Post #235196 13th May 2013 5:11pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
You could use one of these.
http://www.towsure.com/product/SelfSwitching_Combination_Relay
use one output for 1 st battery and instead of connecting to a fridge use the second outlet to the 2nd battery
Place simple switch in line to switch on and off.
Post #235216 13th May 2013 6:10pm
Tiger
why no common earth ?
what sort of current/amps are you thinking of running thru? (20amps you should be thinking of adding a relay)
Fuses are a good idea too
Jamie will be along with a wiring diagram shortly Thumbs Up
Post #235228 13th May 2013 6:35pm
K9F
Ironically I have a project on the go that I needed to source some DPDT relays 10 amp rated. If these suit your needs here are the RS details to save you scratching around....Just a cut and paste job from my e-mail order.
RS ITEM NUMBER 402-213,
RELAY SOCKET 8 PIN
PAGE 1217
PRICE £6:48 EACH
RS ITEM 376-385
DPDT 10 AMP RELAY
PAGE 1217
PRICE £9:29 EACH If you go through life with your head in the sand....all people will see is an ar5e!!
Post #235237 13th May 2013 6:58pm
Splitpin
I'm sure we should throw in the ability to run them in 24v configuration also Wink
How are they charged?
Post #235240 13th May 2013 7:18pm
Tiger
2x Cteks
Post #235248 13th May 2013 7:48pm
