![]() | Home > Technical > Electrics and diagnostics 1998 TD5 |
Yes, it's the OBD socket.
Not sure. Could be the loom for a heated windscreen. What colours are the wires?
Not familiar with the Madman, but I've got one of the older Nanocoms and it tells you all you could reasonably need to know about the TD5. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
Re Madman vs Nanocom etc...
The madman is a monitoring system, the Nanocom is a diagnostics system. You would't normally leave a Nanocom plugged in all the time and it won't warn you when something goes out of it's normal operating range. You can use a Nanocom to get more detailed information about the ECUs and change their settings. The Madman is permanently connected and you can set low and high alarm levels for everything it's monitoring so it can draw your attention to a problem as soon as it happens. You can't change ECU settings or interrogate the ECU with a Madman. Ideally you'd have both but the madman is the only one of the two that could be described as a monitoring system. http://www.yorkshireoffroadclub.net/ |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
Nanocom you can run in "instrument mode" which shows you batt voltage, water temp, RPM and boost pressure, but doesn't trigger any alarms if they go out of limits.
