![]() | Home > Tdi > Removing silencer box, which one? |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
Most certainly the mid box, keep the rear box on for some back pressure and jobs a gooden
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21020 ![]() ![]() |
The mid section you will get more from and as mentioned above. You should get a nice note under acceleration and a little more torque.
And my straight through is a Terrifirma. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Didnt realise you had one fitted Steve, The terrafirmas are good value for money and do the job perfectly. I must get round to fitting a stainless on my 90 to make it sounds less like a transit
Yep, I do indeed Chris. What do you have? If your after a full system for the time being stick a straight through on they are only £50 - £100 and make a good exhaust note. More throaty like a TD5 than Transit. I also swear there is more go in it when you put your foot down. Less resistance if that makes sense. ____\We|Will|Win/___
I have our own range of 302 grade stainless exhausts so will stick one of them on when i get time
Do you personally make them do you?
![]() ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Yer out of house guttering
I suppose it would be possible to paint with VHT paint but I don't know exactly what temperature the exhaust gets especially manifold end. That and of course it would be totally pointless.
Arierep Member Since: 13 Apr 2013 Location: Portugal Posts: 258 ![]() ![]() ![]() |
Thanks for the help
I was under the impression that the correct one to remove was the center box, but words from a respected mechanic in my area confused me a bit. He really insisted that the better one to remove was the rear one |
Perhaps for the sound only but it will do nothing for the performance. I've only ever really known people change the rear silencer if they change to a full straight through system (usually Stainless) some say there can be issues with there being no back pressure and others say it's fine. Personally I'd either just go for a straight through mid section as I have OR a full system. Just the rear seems like little point to me.. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Those said back pressure issue are what keeps me from going full straight. Never really went on to fully understand those issues, can someone please explain them better? Thanks again |
Centre box removal does seem the most 'popular' however I binned the cat and the rear box with my stainless system. Didn't like the rear box anyway it was ugly as sin..... ![]() Made from 304 grade stainless with a lifetime no quibble guarantee...straight from the horse dentist's mouth so to speak. ![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
[/quote] That was actually one of the arguments of the said mechanic, that the rear box had an internal "labyrinth" and the center box was more straight, therefore restricting less the system. Any comments? Thanks |
