| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
I Think they did a water test on it a couple of times and said it was fine
I'll tell them about the window seal NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
My Puma leaked from the windscreen seal as well. Have mentioned this before but had two windscreen replacements last year Autoglass said that with Defenders the windscreen seal lower edge is a known problematic area. When removed I could see what they meant, on the outside the amount of cr4p that accumulates there is amazing, at a year old the water and dirt sitting in there was a real 'eye opener.' Eventually either crud build up and/or corrosion will allow water in. The only cure is sealant. They cleaned mine down and applied sealant before refitting the screen. Result - no more water dripping from under the dash!
Cheers Mal, i'm going in next week i'll tell them to check it out see what they say
| Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514
Trust you to pick up on that Grockle, you tart, |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
they'll prob say it's the r r r rain causing the leak 1968 1/32 scale Britains 109 Pick up. |
| johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371
Had a bit of fun with the kids plowing thorugh snow burms in a parking lot, until I took on a burm that was a bit to high for the 110...and you guessed it, got high centered!!!
Half an hour with a snow shovel and some serious rocking back and forth and we were free. Oops, total dumb rookie mistake! oh well, it is still a great vehicle even if the driver is a nit wit IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
| willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789
Went down this hill last saturday, it's way steeper than the photo. Set off through a few drifts at the top no problem, came to this bank in low first and set off sledging, totally out of control 150' drop one side, spun round a few times until eventually the front wedged itself in a snow bank. Wife was screaming I was shouting
Anyway spent an hour gritting the bank and managed to get down by using the ditch at the side off the road Oh nearly forgot when we where at the bottom saw the Jap 4x4 come back over the top, spun round and round stuffed the front end into the hard snow, his wife got shouting at him, promptly fell on her arse and slid down the bank So don't take for granted you're ok in a 4x4 Original Member Pie n Pea Club.
110 HCPU Tipper Last edited by willy eckerslike on 4th Feb 2010 7:50am. Edited 1 time in total |
What was more traumatic - Having the missus bawl you out or balancing precariously over a 150' drop?
Riveting read Willy, probably would have filled my breeches and the cab to boot. Was exciting as last week's Silent Witness! Treat every day as if it is your last....one day you will be right!! |
where abouts were ya willy 2.4 90 XS
Farndale bank, from the Hutton le Hole to Castleton road. I was going to meet RLD and Border Rover at the Trekoverland HQ, prior to having a session with RLD, Border Rover and spouses at the Lion Inn Blakey
It's not a nice feeling being out of control but certainly gets the adrenalin pumping, did have a bit of a shake on for a while. Told the wife she would feel good all day after the adrenalin buzz, she promptly punched me You can see the chewed up snow at the top of the bank, then where i got it straightened out and came down. Only damage was bent both rear mudflap mounts under, other than that the winch bumper and rear NAS step and spare wheel saved me. Original Member Pie n Pea Club. 110 HCPU Tipper |
lucky escape then mate,nice part of the country go near there on way to Whitby sometimes 2.4 90 XS
| adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389
Wife needed a round bayle of Hay fo the ponies..Sankey was behind the horsebox that needed a jump start..So off came the rear canopy and off i went. The big round bayle fitted nicely in the back of the DC pickup area... Putting Dreams on Drives at JLR Solihull..
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
Today I parted with cash and got me a Sankey
Glyn |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
Put the analog odometer from the 1984 90 in the TD5 and changed the right hand door window guides. Had to use the old window again as I could not use the TD5's window regulator as the whole inside off the doors are different. It's not perfect yet I need a new window regulator as some teeth are a little worn
Still more work to do for it's first Dutch MOT as a 1984 (tax free) Td5. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| All times are GMT |
