Home > Maintenance & Modifications > Installing a aux power socket in the rear
Page 1 of 11 123 ... 91011>
ericvv
Have read several posts about a permanent powered purple and black wire behind one of the rear speaker panels. For us continental Left Hand Drivers that would be on the passenger side. Have checked it, and yes it is there, a black wire and a purple wire ending in a double spade plug, but otherwise unused. These wires are protected by the same 20A fuse of the towing socket. I can assure you about that, because I blew it today and had to replace the fuse. Mr. Green
As our Defenders come standard with only one interior power socket, on the center dash, I thought it would be good to use these unused permanent powered wires for a 2nd power socket. I ordered one from Mud-UK, and installed it today.
Very easy mod, but quite useful to power up a electric coolbox in the back or other.
Here some pictures about what I did today.
Dismantling the rear panels reveals the little loom in question
Detail of the purple and black wires and their spade connector
Drill a hole in the panel just big enough to push the socket through. I drilled several smaller holes, then used a sharp cutter, and finished it off with a circular file to get the hole just perfect for a tight fit.
Frontal look of the assembled Mud socket
Made a little extension to the wires as the wires spade connector is no direct fit to the socket connector
Connecting it all up. Mind, you will notice that on one of the Mud socket connectors is a tiny + showing.
The purple wire is the + and I connected that properly to the Mud + connector via my red extension wire. The blue extension goes between the black wire of the loom which is the - and the unmarked connector of the Mud socket
Reassembling everything...
Final result. Pretty happy with it, useful little mod for almost no money Thumbs Up
Last thing I did was replace the 20A fuse which I blew in the process, but have no pics of that Whistle You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #234094 9th May 2013 2:33pm
MartinK
Lots of great information, with good pics to boot. This is a regular request and should be STICKIED imho... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #234113 9th May 2013 3:40pm
Martin
Site Admin
Done Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #234114 9th May 2013 3:44pm
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Nice write up - found my wires whilst Dynamat'ing my 110 last weekend. On the job list... Cheers,
Superspoons
Post #234118 9th May 2013 3:50pm
Martin wrote:
Done Smile
A good choice there and good guide. Mr. Green
The only recommendation I'd make is that the extension bit you've used is fine but I'd use fully insulated female crimp terminals to the the rear of the socket like these:
Just because the live is a little exposed and could cause a short if anything comes into contact with it and the body.
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #234120 9th May 2013 3:57pm
ericvv
Couldn't agree more with that Steve. I will replace those asap by fully insulated, but when I started this little job this morning and found that I ran out of the needed crimp terminals I had only one chance on this Ascension thursday when everything is closed, and that was a French supermarket which was open this morning Mr. Green . Will get that corrected before the week is over as stores are open tmrw again Thumbs Up . You never actually own a Defender. You merely look after it for the next generation.
Post #234126 9th May 2013 4:12pm
You had the same issue as me then of running out over the Bank Holiday weekend. Thumbs Up Didn't mean to intentionally criticise just though it's better to be safe than sorry. After all we all know what insurance companies are like if anything happened for example worse case scenario fire. Rolling Eyes Rolling Eyes
Post #234137 9th May 2013 4:30pm
This is a useful mod that is relevant to TD5's (and probably 300tdi's) too. It's worth noting though that the spare wires have been deleted on 13MY vehicles. Very short sighted of Land Rover IMHO. Darren
Post #234140 9th May 2013 4:53pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
That reminds me must do mine so that I can have a beer fridge when talking the caravan away.
Post #234142 9th May 2013 5:02pm
custom90steve wrote:
Martin wrote:
Done Smile
Thumbs Up
or, pop a bit of heat shrink over the existing
Post #234145 9th May 2013 5:11pm
That would work too. Thumbs Up ____\We|Will|Win/___
Post #234149 9th May 2013 5:23pm
Defpuma
United Kingdom 2013 Defender 90 Puma 2.2 HT Santorini Black
Brilliant post ericvv and something I have been meaning to do for ages. Something that everyone would get use from. Why does it not just come as standard from the factory like this?
Post #234515 10th May 2013 10:33pm
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
Are these the same cables that could be used for a work light?
Post #234519 10th May 2013 10:45pm
SGH
Same wires can be found on a Hicap they are just left dangling under the back of the rear crossmember.
Post #234544 11th May 2013 6:10am
ericvv
Saw this week that on a model year 2013 Puma 2.2 station wagon that there are two wires ending in a plug dangling out 10 cm or so from the right hand side chassis rail somewhere 20 cm or so before the rear crossmember. Saw it at a friends new Defender while we were at the dealer. When asked about what these cable are for, they just did not know. Could it be that after the purple and black live wires behind the right hand side rear speaker panel were abandoned on model year 2013, that those wires/plug dangling out of the chassis rail are the new live wires which could eventually be used for a rear work light or other? A rear work light remains an option, so the juice must be taken somewhere, yes? Any 2013 model year drivers able to shed light on this?
Post #234557 11th May 2013 8:31am
