Home > Td5 > Help with Spluttering TD5
Page 2 of 3 <123>
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
Re: Try this
Thank you for the Info i will check the MAF and report back.
Butters wrote:
Unplug the mass airflow meter.
It's in between the air box and the turbo.
After a few seconds of driving the car will use the ECU preset safe fuelling instead of relying on the MAF. For the first few seconds its gonna drive slow and bad acceleration then it goes like fxxj
If the Defender then runs great, buy a new MAF sensor fit and enjoy. Don't run long term with no MAF you will waste fuel and be under and over fuelling depending on the revs
To test the waste gate use some mole grips on the actuator rod that goes towards the turbo, push it firmly towards the bulkhead of the car, if it moves in and out waste gate is fine
The injector loom is £35 ish, if you can't remember when. It was last done just do it, they last two to three years then start leaking through the loom and can make a mess of the ECU so treat as a service item every two to three years methinks
My guess is kangaroo ing or jerky power spluttering, more than likely the MAF
Post #225188 7th Apr 2013 1:44pm
ttuck3r
Fitted new injector loom and gasket, cleaned out the oil on the ecu side, waxoyled the engine bay and every plug got cleaned an dielectric grease blasted through. i will report back on results..
Post #225189 7th Apr 2013 1:44pm
Martyn668
Thanks to Tucker and everyone.else here. I tried the turbo wastegate, and it was indeed pretty much seized. A bit of 3-in-1 oil, a few wiggles with the molgrips and it's sorted. Cost 2p! Excellent. Thanks again.
Post #225788 9th Apr 2013 2:42pm
johnnyd
How much play should there be on this valve, i can move it about 1CM isn, but its hellishly loaded?
JD
Post #227744 16th Apr 2013 10:04am
ttuck3r
Cleaned out the MAP sensor on the manifold with still no joy, next is the wastegate and MAF sensor.
Post #232970 5th May 2013 8:06pm
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
Certainly sounds like the waste gate, I experienced all the symtoms desribed new loom, ECU plug off and cleaned, but still missing at the top end in each gear,
Eventually mine stared seriously misfiring and fortunatley managed to get back to our local garage who remedied the problem identified on their diagnostic gizmo as a siezed wastgate.
A year down the road it's still fine pulls really well massive difference Thumbs Up
Get out the mole grips
DRW I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #233673 7th May 2013 10:40pm
johnnyd
....How much play should there be on this wastegate valve, i can move it about 1CM ish, but its hellishly loaded?
JD 2008 TDCi 2.4 XS CSW
Post #233716 8th May 2013 8:49am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
john....hang on send you a you tube link.... Wink  Putting Dreams on Drives at JLR Solihull..
Post #233723 8th May 2013 9:28am
landy andy
Did mention waste gate, and post video 9 days ago in this post Whistle Whistle Whistle Whistle Whistle Whistle
Andy
Post #233725 8th May 2013 9:35am
johnnyd
LoL i never thought of looking for a you tube vid..... Wink
Mine does not have this much play ...http://www.youtube.com/watch?v=FyZ4zXPZOf8
So may still be stuck 2008 TDCi 2.4 XS CSW
Post #233726 8th May 2013 9:37am
ttuck3r
Thanks to everyone for all the useful info and videos i overcame my fear of breaking the wastegate and found it was jammed..
Well i think the splutter is gone, went for a drive and she seems to be pulling a lot better too.
I got a new MAF sensor but once i replaced it i also gave the wastegate another push pull to find it was completely jammed up, so i sprayed a combination of GT85 and WD40 until it released and now all seems to be running sweet.
Below is a list of replaced/fixed parts that got me to the end eventually.
1st was the cleaning out of the ECU which had oil sat in the red plug
2nd was the replacement of the injector loom which had oil ingress right through and the ecu has been cleaned out every fortnight since
3rd A new fuel filter and fuel return hose was replaced due to rust on the filter and leaking hose.
4th MAP sensor on manifold was removed and thoroughly cleaned out
5th MAF sensor replaced
6th the wastegate released as it was jammed
Hope this can help someone else
Post #234603 11th May 2013 12:16pm
johnnyd
what is it that sticks with this wastegate, is it the valve bit or the section in the manifold, i am sure mine is sticking/stiff but not sure what to try to free up
Post #236505 18th May 2013 7:13am
Where the thing piece of rod goes into the round actuator. it jams in the actuator, meaning the wastegate stays shut (or partially closed) and thus the boost can't be leaked off to keep within what its been set at, and then you get the overboost.
Post #236507 18th May 2013 7:30am
johnnyd
diesel_jim what sort of force is necessary to actuate this? If i put a pair of grips on the rod, with all my force i can move the arm about 1-2cm, does that sound right ?
Post #236508 18th May 2013 7:33am
You'll need grips to move it, yes.
Ian @ IRB did a youtube video clip showing it <-----
Post #236547 18th May 2013 10:38am
Page 2 of 3 <123>
