Home > Maintenance & Modifications > Drawer runners
Page 1 of 3 123>
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Drawer runners
Hi,
I'm planning on building a set of rear drawers for my Def90 and am struggling to find a supply of long (approx 1 metre) drawer slides at a decent price.
Any suggestions for suppliers, or alternative installation ideas welcome.
Simon
Post #232610 4th May 2013 9:12am
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
RS Online stock the accuride runners which are about the best but not cheap!
You might be able to find a local stockist via Hafele the wholesalers for accuride.
900mm ones here,
http://uk.rs-online.com/web/p/drawer-slides/3826928/
Whole range to view,
http://www.accuridedrawerslides.co.uk 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #232622 4th May 2013 10:00am
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Accuride as already stated Thumbs Up
Another place to buy them from: Components Direct
Post #232624 4th May 2013 10:17am
couplands
Thanks, I've seen the Accuride runners, great product, but my design needs 7 pairs, so was hoping for something less than £100/pair (considerably less..!).
At those prices, I need an alternative design... Shocked
cheers
simon
Post #232628 4th May 2013 10:53am
db950
Wow 7 pairs, that's some drawer system!!!
Coud you just not use friction slides? 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #232636 4th May 2013 11:22am
Cracka
2012 Defender 90 Puma 2.2 HT Fuji White
Re: Drawer runners
couplands wrote:
Hi,
Simon
Post up some pics if you don't mind when you do it. I'm toying with the idea myself.
Post #232638 4th May 2013 11:29am
couplands
I have considered it, but I want to be able to pull the drawers out and have them support themselves. If I rely on friction runners, I would only be able to pull them 1/2 way out, otherwise they'd fall out..!
I've ended up with 7 drawers as I want to split the load area. 2 for waffle boards, 2 for ropes/towing/recovery gear, 1 for the high lift jack, 1 for food and 1 for cooker/worktop space.
cheers
simon
Post #232683 4th May 2013 6:21pm
couplands
Re: Drawer runners
Cracka wrote:
couplands wrote:
Hi,
Simon
Here is my initial rough sketch of what I want to achieve. I'm learning Google Sketchup so I can make a better set of drawings. However, if I cant find affordable drawer slides, Ill need to find another approach.
Any comments/ideas welcome.
cheers
simon
Post #232686 4th May 2013 6:25pm
Glynparry25
Due to them not having much weight you should get away with runners from your local B&Q t about £10 a pair (about 70-90cm)). Do you need the full meter, I have been looking for mine and the set I am now look at are 70cm long and will cost me 6 Euros each.... for a saving of £90 a pair I can live with them being 30cm short. The weight limit is only 60Kg for a pair, but with so many draws I am guessing you wont have that weight in yours.
Glyn Dog Sheep
Post #232693 4th May 2013 7:35pm
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Another vote for Accuride. I use a 1m set for an Engel slide.
Sketchup is a good tool too Thumbs Up My Disco 'best bits'
Defender 110 XS CSW 2013
Post #232694 4th May 2013 7:37pm
couplands
Glyn Dog Sheep
Glyn,
As you say, with so many drawers I don't need so much weight. I only need a metre for the waffle boards. If I could get 90cm I'd be happy. A trip to B&Q sounds a good idea... Thumbs Up
Cheers for the idea...
Simon
Post #232695 4th May 2013 7:46pm
Do you really need a drawer for the waffles? Why not just a suitably sized slot? The other thing with waffles is that they're a pain to stow inside when they're full of mud. Darren
Post #232699 4th May 2013 7:54pm
couplands
I was thinking of a slot, but as you say they can get full of mud. My idea was to create a tray, on rails, that they can sit in and I can remove if/when they get covered in mud. If it was just a slot, I think it would get full of mud that would be hard to clean.
I don't want the waffle boards on the outside, and this was the only practical way I could get them inside.
I don't envisage using them a lot, its just for emergencies.
Simon
Post #232713 4th May 2013 8:35pm
How about a bag to put them in first? Darren
Post #232720 4th May 2013 8:48pm
couplands
If the rails aren't an option a bag would be a great idea Thumbs Up
Simon
Post #232724 4th May 2013 8:59pm
Page 1 of 3 123>
